As some of you may know, there is bug in the installer of Lubuntu regarding full disk encryption with LVM. I have read at multiple places to use
sudo swapoff --all
as a workaround. That does not work for me, instead of the common error message I get the following:
Autopartitioning using LVM failed because an error occurred while creating the volume group. Check /var/log/syslog or see virtual console 4 for the details.
So here is a part of /var/log/syslog that I find relevant for my problem:
Nov 4 08:28:21 lubuntu ubiquity: /bin/autopartition-crypto: 292: /bin/autopartition-crypto: pvs: not found
Nov 4 08:28:21 lubuntu ubiquity: /var/lib/partman/devices/=dev=sda
Nov 4 08:28:21 lubuntu kernel: [ 104.080652] sda: sda1 sda2 sda3
Nov 4 08:28:21 lubuntu kernel: [ 104.555330] sda: sda1 sda2 sda3
Nov 4 08:28:22 lubuntu partman: mke2fs 1.43.3 (04-Sep-2016)
Nov 4 08:28:22 lubuntu partman-crypto: kernel entropy_avail: 977 bits
Nov 4 08:28:22 lubuntu kernel: [ 104.887497] NET: Registered protocol family 38
Nov 4 08:28:29 lubuntu ubiquity: stat: cannot stat '/dev/lubuntu-vg'
Nov 4 08:28:29 lubuntu ubiquity: : No such file or directory
I am not sure what is wrong, there seems to be some program missing. I am also going to try an installation off of the alternate installer. Can you please give my some suggestions how to fix the problem?
