The simplest way is to use ping -c4 google.com to test your internet connection. If it can reach out beyond your router to any url, then you have internet access. This can easily be adapted to a script that periodically pings a site you choose. But I've a slightly different idea.
Here's a top-panel indicator that'll periodically request internet connection. If your internet connection goes down, it's icon will change to warning sign. It uses standard icon names, so no need to add any additional icons.
Save this as file, make sure it has executable permissions with chmod +x interwebs-indicator (from terminal) or via right-click menu in file manager. Run manually in terminal as
python3 intwerwebs-indicator
or
./interwebs-indicator
if have given it executable permissions.
You can make it start automatically on GUI login ,too.
Simple and easy to use.
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
# Author: Serg Kolo , contact: 1047481448@qq.com
# Date: November 3rd, 2016
# Purpose: appindicator for testing internet connection
# Tested on: Ubuntu 16.04 LTS
# Licensed under The MIT License (MIT).
# See included LICENSE file or the notice below.
# Copyright © 2016 Sergiy Kolodyazhnyy
# Permission is hereby granted, free of charge, to any person obtaining a copy
# of this software and associated documentation files (the "Software"), to deal
# in the Software without restriction, including without limitation the rights
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
# copies of the Software, and to permit persons to whom the Software is
# furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included
# in all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
import gi
gi.require_version('AppIndicator3', '0.1')
gi.require_version('Notify', '0.7')
from gi.repository import GLib as glib
from gi.repository import AppIndicator3 as appindicator
from gi.repository import Gtk as gtk
from gi.repository import Gio
from gi.repository import Gdk
import urllib.request as urllib2
class InterwebsIdicator(object):
def __init__(self):
self.app = appindicator.Indicator.new(
'interwebs-indicator', "gtk-network",
appindicator.IndicatorCategory.HARDWARE
self.app.set_attention_icon('dialog-warning')
#self.app.set_status(appindicator.IndicatorStatus.ACTIVE)
self.make_menu()
self.update()
def add_menu_item(self, menu_obj, item_type, image, label, action, args):
""" dynamic function that can add menu items depending on
the item type and other arguments"""
menu_item, icon = None, None
if item_type is gtk.ImageMenuItem and label:
menu_item = gtk.ImageMenuItem.new_with_label(label)
menu_item.set_always_show_image(True)
if '/' in image:
icon = gtk.Image.new_from_file(image)
else:
icon = gtk.Image.new_from_icon_name(image, 48)
menu_item.set_image(icon)
elif item_type is gtk.ImageMenuItem and not label:
menu_item = gtk.ImageMenuItem()
if '/' in image:
else:
icon = gtk.Image.new_from_icon_name(image, 16)
elif item_type is gtk.MenuItem:
menu_item = gtk.MenuItem(label)
elif item_type is gtk.SeparatorMenuItem:
menu_item = gtk.SeparatorMenuItem()
if action:
menu_item.connect('activate', action, *args)
menu_obj.append(menu_item)
menu_item.show()
def add_submenu(self,top_menu,label):
menuitem = gtk.MenuItem(label)
submenu = gtk.Menu()
menuitem.set_submenu(submenu)
top_menu.append(menuitem)
menuitem.show()
return submenu
def make_menu(self):
self.app_menu = gtk.Menu()
self.add_menu_item(self.app_menu,gtk.ImageMenuItem,'exit','quit',self.quit,[None])
self.app.set_menu(self.app_menu)
def check_connection(self,*args):
try:
url = urllib2.urlopen('http://google.com')
page = url.read()
except urllib2.HTTPError:
print('>>> err:')
self.app.set_status(appindicator.IndicatorStatus.ATTENTION)
#self.app.attention-icon('network-error')
except Exception as e:
print('>>> exception:',e)
else:
print('>>> OK')
self.app.set_icon('network')
def callback(self,*args):
timeout = 5
glib.timeout_add_seconds(timeout, self.update)
def update(self,*args):
self.check_connection()
self.callback()
# General purpose functions
def quit(self,*args):
gtk.main_quit()
def run(self):
""" Launches the indicator """
try:
gtk.main()
except KeyboardInterrupt:
pass
def quit(self, *args):
""" closes indicator """
gtk.main_quit()
def main():
""" defines program entry point """
indicator = InterwebsIdicator()
indicator.run()
if __name__ == '__main__':
try:
main()
gtk.main_quit()
