I am using Ubuntu 16.10 and I have a problem with the drivers for BCM43142 (14e4:4365). I have already installed Broadcom-STA. Version v6.30.223.271 which I got from: http://de.archive.ubuntu.com/ubuntu/pool/multiverse/b/broadcom-sta/ using dpkg. (4th version) But it still does not work.
~$ sudo dpkg -i ~/Downloads/broadcom-sta-common_6.30.223.271-4_all.deb
[sudo] password for jan:
(Reading database ... 204118 files and directories currently installed.)
Preparing to unpack .../broadcom-sta-common_6.30.223.271-4_all.deb ...
Unpacking broadcom-sta-common (6.30.223.271-4) over (6.30.223.271-4) ...
Setting up broadcom-sta-common (6.30.223.271-4) ...
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.125ubuntu5) ...
update-initramfs: Generating /boot/initrd.img-4.8.0-26-generic
W: Possible missing firmware /lib/firmware/i915/kbl_guc_ver9_14.bin for module i915
W: Possible missing firmware /lib/firmware/i915/bxt_guc_ver8_7.bin for module i915
~$ sudo modprobe wl
modprobe: ERROR: ../libkmod/libkmod-module.c:832 kmod_module_insert_module() could not find module by name='wl'
modprobe: ERROR: could not insert 'wl': Unknown symbol in module, or unknown parameter (see dmesg)
modprobe: ERROR: ../libkmod/libkmod-module.c:977 command_do() Error running install command for wl
modprobe: ERROR: could not insert 'wl': Operation not permitted
Thank You for helping
