I want to install ubuntu alongside Windows 10 (which is already installed in my pc) in my pc, i was trying to shrink volume of C:\ drive by disk management but my C:\ drive don't have enough space . Will it work if i shrink my D:\ or E:\ drive in stead of C:\?
I also tried using USB drive by downloading unetbootin but found no result.
Please give a detailed explanation if possible.
IAmBlake
  • 103
You can use the utility gparted within a live USB or CD install to resize your disk offline. It should come preinstalled however if it is not you can run 'sudo apt-get install gparted' to install it.
I happen to find the 'Universal USB Installer' the easiest to use on Windows whenever I try to make a bootable USB key.
Aedazan
  • 312
-3
Yes, shrinking the D or E drive can work. Look at this video.
For USB bootable OS, do this :
  1. Download ISO file of ubuntu (any version)
  2. Download Universal USB Installer (UUI) from here
  3. Connect your USB drive and run UUI and follow the process.
  4. After 10-20 minutes it will create a bootable USB.
  5. Restart your system and boot from the USB drive.
  6. Install it and enjoy Ubuntu on your system.
wjandrea
  • 14,504
