Yesterday I installed Ubuntu, however, after the install had finished there were no bootable operating systems. Neither my Windows 10 or Ubuntu would launch. After reading around I found repair boot, made a live CD, and "fixed" the grub. This allowed me to launch my Ubuntu OS but it still would not let me launch my Windows 10.
This brings me to a few hours ago. Since then I have not been able to fix my system so it launches Win10. I can mount my hard drive that had my Win10 OS on and that was not touched during Ubuntu setup, I have tried the methods here (except manually writing an entry).
I have also tried booting on the HDD that has the partition for Win10 but that provides me with a black screen and a flashing white line. The same result that I had before I ran boot repair and got Ubuntu to work.
So I am asking how can I boot into windows, either by booting onto the hard drive that contains it or adding it to the Grub Ubuntu launches off?
Edit
I forgot to mention my secure boot is disabled so that is not the issue here
Edit
lsblk
NAME                MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sda                   8:0    0  58.7G  0 disk
├─sda1                8:1    0   243M  0 part /boot
├─sda2                8:2    0     1K  0 part
└─sda5                8:5    0  58.5G  0 part
sdb                   8:16   0   2.7T  0 disk
├─sdb1                8:17   0   128M  0 part
└─sdb2                8:18   0   2.7T  0 part
sdc                   8:32   0   1.8T  0 disk
├─sdc1                8:33   0 927.3G  0 part
├─sdc2                8:34   0   450M  0 part
└─sdc3                8:35   0 935.3G  0 part
sr0                  11:0    1  1024M  0 rom
sudo lshw | grep -A9 firmware
 *-firmware
      description: BIOS
      vendor: American Megatrends Inc.
      physical id: 0
      version: F2
      date: 07/15/2013
      capacity: 4032KiB
      capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification uefi
     *-cpu
            configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168e-3_0.0.4 03/27/12 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
            resources: irq:28 ioport:b000(size=256) memory:fe200000-fe200fff memory:da100000-da103fff
    *-pci:5
         description: PCI bridge
         product: SB900 PCI to PCI bridge (PCIE port 2)
         vendor: Advanced Micro Devices, Inc. [AMD/ATI]
         physical id: 15.2
         bus info: pci@0000:00:15.2
         version: 00
         width: 32 bits
            configuration: broadcast=yes driver=ath9k driverversion=4.3.0-kali1-amd64 firmware=N/A ip=192.168.1.128 latency=0 link=yes multicast=yes wireless=IEEE 802.11abgn
            resources: irq:18 memory:fe100000-fe11ffff memory:fe120000-fe12ffff
    *-usb:5
         description: USB controller
         product: SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
         physical id: 16
         bus info: pci@0000:00:16.0
         version: 00
         width: 32 bits
Dan
  • 155
It would seem that your Windows was installed in BIOS mode as there is no EFI partition on /dev/sdc but the system is currently in EFI mode per lshw output. You should be able change this setting in your BIOS to either UEFI and Legacy or Legacy and if nothing else is awry the system should boot. The aforementioned discrepency between boot mode and installation mode is very likely what is confusing boot-repair (which you will likely need to run again once your system is booting in the same mode that you installed your operating systems.
Elder Geek
  • 36,752
