On Ubuntu 16.04LTS, I'm trying to install TigerVNC:
monkey@Sonic ~/Downloads $ sudo dpkg -i "tigervncserver_1.7.0-1ubuntu1_i386 (1).deb"
Selecting previously unselected package tigervncserver:i386.
(Reading database ... 259378 files and directories currently installed.)
Preparing to unpack tigervncserver_1.7.0-1ubuntu1_i386 (1).deb ...
Unpacking tigervncserver:i386 (1.7.0-1ubuntu1) ...
dpkg: dependency problems prevent configuration of tigervncserver:i386:
 tigervncserver:i386 depends on libtasn1-3-bin.
dpkg: error processing package tigervncserver:i386 (--install):
 dependency problems - leaving unconfigured
Processing triggers for systemd (229-4ubuntu10) ...
Processing triggers for ureadahead (0.100.0-19) ...
Processing triggers for man-db (2.7.5-1) ...
 tigervncserver:i386
monkey@Sonic ~/Downloads $ sudo apt-get install libtasn1-3-bin
Reading package lists... Done
Building dependency tree
libtasn1-3-bin is already the newest version (4.7-3ubuntu0.16.04.1).
libtasn1-3-bin set to manually installed.
You might want to run 'apt-get -f install' to correct these:
 tigervncserver:i386 : Depends: libtasn1-3-bin:i386 but it is not installable
                       Recommends: x11-xserver-utils:i386 but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
When I ran sudo apt-get -f install, it offered to remove tigervncserver:i386.
What am I doing wrong? Thanks.
UTAN_dev
  • 131
libtasn1-3-bin:i386 does not exist in Xenial, as the package libtasn1-3-bin is for all, so this package you have downloaded cannot normally be installed on Xenial. Maybe try looking for another one.
fkraiem
  • 12,813
