sorry, still quite a new-be with Ubuntu and thus may not see the obvious.
I have installed Ubuntu 16.04LTS as well as 16.10 from scratch on a small Intel machine with a German keyboard attached. The system language is set to English, but the keyboard to standard German. When working on the system directly all is normal.
I have installed x11vnc as server on the box and access it from a Windows 7 notebook with a standard German keyboard using VNC Viewer 5.3.2.
The access generally works, but I noticed that some special characters are not being submitted correctly. The main problems I have are with @ and |.
I have tried setting special options on the server side such as -xkb, -remap DEAD,-add_keysyms, -noadd_keysyms, but none is the solution. One of them - forgot which after all changes - gave me the wanted characters, but suddenly I could not get the ! anymore.
Edit: Just tested other VNC clients under Windows (VNC Viewer 6.0.0, TightVNC Viewer 2.8.5) with the same results. Must be an issue between Windows and Ubuntu as such.
What I am doing wrong? Thanks!
