I tried to install several python nautilus extensions (i.e. nautilus-columns, nautilus-open-as-root,... ) without any success. Installation goes fine, but nothing shows up in nautilus.
Of course, package python-nautilus is already installed:
ii  python-nautilus                                             1.1-8                                               amd64        Python binding for Nautilus components
Digging a little bit, I discovered that nautilus was complaining when starting:
ImportError: could not import gobject (could not find _PyGObject_API object)
(nautilus:18199): Nautilus-Python-WARNING **: pygobject initialization failed
(nautilus:18199): Nautilus-Python-WARNING **: nautilus_python_init_python failed
Looks like an issue with gobject library or something like that.
As I'm running Ubuntu 14.04.5 with python upgraded, may be the issue is there ? Here is an extract of some packages available on my distribution:
ii  libpython-stdlib:amd64                                      2.7.5-5ubuntu3                                      amd64        interactive high-level object-oriented language (default python version)
ii  libpython2.7-stdlib:amd64                                   2.7.6-8ubuntu0.2                                    amd64        Interactive high-level object-oriented language (standard library, version 2.7)
ii  libpython3-stdlib:amd64                                     3.4.0-0ubuntu2                                      amd64        interactive high-level object-oriented language (default python3 version)
ii  libpython3.4-stdlib:amd64                                   3.4.3-1ubuntu1~14.04.4                              amd64        Interactive high-level object-oriented language (standard library, version 3.4)
ii  python                                                      2.7.5-5ubuntu3                                      amd64        interactive high-level object-oriented language (default version)
ii  python-gi                                                   3.12.0-1ubuntu1                                     amd64        Python 2.x bindings for gobject-introspection libraries
ii  python-gobject                                              3.12.0-1ubuntu1                                     all          Python 2.x bindings for GObject - transitional package
ii  python-gobject-2                                            2.28.6-12build1                                     amd64        deprecated static Python bindings for the GObject library
ii  python2.7                                                   2.7.6-8ubuntu0.2                                    amd64        Interactive high-level object-oriented language (version 2.7)
ii  python3                                                     3.4.0-0ubuntu2                                      amd64        interactive high-level object-oriented language (default python3 version)
ii  python3-gi                                                  3.12.0-1ubuntu1                                     amd64        Python 3 bindings for gobject-introspection libraries
ii  python3.4                                                   3.4.3-1ubuntu1~14.04.4                              amd64        Interactive high-level object-oriented language (version 3.4)
What made me question python version / gobject / v2.7 and v3.4, is also that python-nautilus README file says:
libautilus-extension Python bindings
These are unstable bindings for the nautilus extension library
introduced in Gnome 2.6.
For examples and documentation check the examples sub directory.
As of nautilus-python 0.7.0, scripts are also loaded from $XDG_DATA_DIR/nautilus-python/extensions,
which includes ~/.local/share and /usr/share (or whatever your $XDG_DATA_DIR is
set to).
Try to copy test.py to that directory for an example
Requirements
Nautilus  2.32.0
Python    2.3
PyGObject 2.28.0
Problems
It's currently not possible to reload the python file without
restarting nautilus. That's a planned feature for future versions
=> looks very old, isn't it ?
Latest version of this package seems to be 0.7.3 (2011-03-08). That could explain some compatibility issues with Python 3.4 ? (link to project log)
If yes, how can we proceed to be able to use python extensions for nautilus anyway ? Is there another package to install ? Or can we modify something in this one ?
Any suggestion ?
Thanks !
Thierry
  • 961
