I recently installed Ubuntu 16.10 and since then Ubuntu reboots itself.
the output of: last | grep "Oct 31" is:
aegefel tty7 :0 Mon Oct 31 15:15 gone - no logout
reboot system boot 4.8.0-26-generic Mon Oct 31 15:14 still running
aegefel tty7 :0 Mon Oct 31 15:02 - down (00:04)
reboot system boot 4.8.0-26-generic Mon Oct 31 15:02 - 15:06 (00:04)
aegefel tty7 :0 Mon Oct 31 14:33 - crash (00:28)
reboot system boot 4.8.0-26-generic Mon Oct 31 14:33 - 15:06 (00:33)
aegefel tty7 :0 Mon Oct 31 14:12 - crash (00:20)
reboot system boot 4.8.0-26-generic Mon Oct 31 14:12 - 15:06 (00:54)
aegefel tty7 :0 Mon Oct 31 13:08 - crash (01:04)
reboot system boot 4.8.0-26-generic Mon Oct 31 13:08 - 15:06 (01:58)
Which leads me to believr it's caused by a crash
I don't know what cause this but it happened when I tried to see a movie or when I did a backup
How should I proceed?
EDIT 1
The command more /var/log/syslog* gives me:
Nov 6 18:18:17 aegefel-Akoya-E6424-MD99850 gnome-terminal-[2674]: Allocating size to GtkBox 0x55558d2b47b0 without calling gtk_widget_get_preferred_width/height(). How does the code know the size to allocate?
Nov 6 18:18:31 aegefel-Akoya-E6424-MD99850 gnome-terminal-[2674]: Allocating size to GtkBox 0x55558d2b4120 without calling gtk_widget_get_preferred_width/height(). How does the code know the size to allocate?
Nov 6 18:18:36 aegefel-Akoya-E6424-MD99850 systemd[1]: Starting Stop ureadahead data collection...
Nov 6 18:18:36 aegefel-Akoya-E6424-MD99850 systemd[1]: Started Stop ureadahead data collection.
Then nothing happened during almost 1 minute, so I suppose the pc rebooted.
The command ls -alt /var/crash gives me for today:
total 21672
drwxrwsrwt 2 root whoopsie 4096 Nov 6 14:26 .
-rwxrwxrwx 1 root whoopsie 0 Nov 6 14:26 .lock
EDIT 2
This append only when my CPU is used at 40% - 50% or more (My CPU is an Intel Core i5 6267U 2.9GHz)
EDIT 3
The command sensors gives me the following:
coretemp-isa-0000
Adapter: ISA adapter
Physical id 0: +37.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +34.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +36.0°C (high = +100.0°C, crit = +100.0°C)
acpitz-virtual-0
Adapter: Virtual device
temp1: +38.0°C (crit = +98.0°C)
pch_skylake-virtual-0
temp1: +35.0°C
The high temperature is equal to the critical. Maybe my laptop just overheat and the fan don't have the time to lower the temperature. I tried to lower the high temperature but this automatically lower the critical (the critical must be equal to the high)
EDIT 4
Here you have
And here are the crashes from the 20 november
EDIT 5
After some test, I think the problem is a GPU overheating. In fact, my laptop reboot only when I try to watch a movie, when I tested with some free games on my Laptop or when I used the Unreal Engine 4. The reason my PC didn't reboot with Blender is that Blender use, by default, the CPU (not the GPU). I have an Intel Iris Graphics 550 (Skylake GT3e)
Any idea ?
