I just returned from trip and try to organize a minimum photos taken by my wife and me with 4 devices : our 2 smartphones and 2 cameras.
I choose to rename all the files with PyRenamer (EXIF) like this : YYYYMMDD_HHMMSS.jpg
Both smartphones and one camera were at the local time, no problem. But my wife's camera had a time shift of 5:46.
My question is simple : how could I add 5:46 to each file ?
Thanks a lot in advance.
NOTE: the following does not change either the EXIF data or the actual timestamp of the files - just their names. It may be preferable to change all three consistently (perhaps possible using exiftool?)
It seems to be possible using the perl based prename / rename command, using strptime to read in the formatted time string, then strftime to write it back out after adding an offset - in seconds (implicitly converted to a Time::Piece object).
Based on comments, by "my wife's camera had a time shift of 5:46" you appear to mean 5 hours 46 minutes (rather than, say, 5 minutes 46 seconds), and you require a shift (forward) of 5 x 3600 + 46 x 60 = 20760 seconds. So you could do:
prename -vn -- '
BEGIN{use Time::Piece};
s/\d+_\d+/(20760+Time::Piece->strptime($&, "%Y%m%d_%H%M%S"))->strftime("%Y%m%d_%H%M%S")/e
The -n flag is for testing - remove it when you are sure the command is performing the right conversion.
See this related question How can I batch convert folder names from one date format to another
steeldriver
  • 142,475
