When I try to install ubuntu-restricted-extras, using sudo apt-get install ubuntu-restricted-extras, I get the following error:
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Cristiana Nicolae
  • 4,570
  • 32
  • 46
omkar
Juste wait a few seconds and try again. It's probably because a background process is currently checking for updates.
Mossroy
  • 1,476
It seems apt-get was stopped prematurely while it was still busy doing something as a result, apt is still in a locked state.Do the following:
Restart your machine (sudo reboot) and try to install again.
If at this point you still cant install the, then do the following:
  • Delete the lock file:
    sudo rm /var/lib/apt/lists/lock
  • Delete the lock file in the cache directory:
    sudo rm /var/cache/apt/archives/lock
  • Install ubuntu-restricted-extras:
    sudo apt-get update
