Recently I tried to dual boot Ubuntu 16.04 with Windows 10 on my Acer aspire laptop UEFI and ran into many issues. The main issue being after installation of Ubuntu 16.04, grub2 bootloader worked only the first time and never again even when I tried reinstalling and several workarounds. Ended up having to format the hdd and install Ubuntu 16.04 by itself.
I just picked up an HP Laptop and I definitely want to dual-boot but am afraid that Windows 10 is the problem as I have worked with UEFI many times and never had an issue.
I read on several forums that Windows 10 breaks grub. This was a few months ago. Nothing worked and many others complained of the same issue.
Many suggested reverting back to Windows 8 or 7 and it worked for them.
My question is, now that a few months have passed. Has this issue been resolved?
Does anyone know of a guaranteed method that works?
Has Canonical possibly fixed the issue?
When I first tried my Dual-Boot, Windows 10 was just released.
Is this no longer an issue?
Appreciate any help! I really do not want to even start the process if I am going to run into the same issue.
You seem to think that there is one issue that wreaks havoc with Windows 10/Ubuntu dual-boots. That's not true; there are many issues, most of which occur on only a small subset of computers. Thus, the only way to completely answer your question is to write a book on the subject. Literally, a book. As the author of over 20 published books on computers, I'm not exaggerating.
In some cases, you can install with little preparation and everything will work normally. Other times, you'll run into one of those many problems. To minimize the risk of your encountering a problem, or to help you recover should you do so, you can read up on the way EFI works and how Ubuntu (or other Linux distributions) works with it:
I know that's a long reading list, and you probably don't want to read all of those pages. If you can read just one or two, I recommend Adam Williamson's blog post and/or my page on installing Linux on EFI systems.
Beyond that, you get into specific problem areas. The biggest of these is buggy EFIs that forget their settings. This problem used to be very common but is now less common -- but more common than it should be. HP used to be a known offender in this area, but I get the impression that recent models are fixed. Dell and ASUS seem to be above average in their EFI implementations. Less-popular brands are often troublesome, as a general rule.
Bad instructions are also an issue. In particular, many sites and posts (especially older ones) recommend enabling BIOS/CSM/legacy mode; but if Windows is already installed in EFI/UEFI mode, enabling BIOS/CSM/legacy support is asking for trouble. My page on the CSM describes why in detail.
Rod Smith
  • 45,120
  • 66
  • 108
-1
If Ubuntu still boots but you CANNOT change OS's I have encountered this problem once. If this is the case I think your GRUB is not showing itself long enough or is just not showing itself meaning the show menu option is off. You can fix this by installing grub customizer
sudo add-apt-repository ppa:danielrichter2007/grub-customizer
sudo apt-get update
sudo apt-get install grub-customizer
After installation open grub customizer and navigate to the 'General Settings' tab and under 'visibility' check 'show menu' and increase the 'Boot default entry' value to however long you want in seconds.
Hope this works :).
