I install Spyder3 but when I try to run it, it crash. error log is this:
Traceback (most recent call last):
  File "/usr/lib/python3/dist-packages/spyderlib/spyder.py", line 2331, in main
    mainwindow = run_spyder(app, options, args)
  File "/usr/lib/python3/dist-packages/spyderlib/spyder.py", line 2215, in run_spyder
    main.setup()
  File "/usr/lib/python3/dist-packages/spyderlib/spyder.py", line 734, in setup
    message=_("Spyder Internal Console\n\n"
  File "/usr/lib/python3/dist-packages/spyderlib/plugins/console.py", line 74, in __init__
    self.find_widget.set_editor(self.shell)
  File "/usr/lib/python3/dist-packages/spyderlib/widgets/findreplace.py", line 260, in set_editor
    from spyderlib.qt.QtWebKit import QWebView
  File "/usr/lib/python3/dist-packages/spyderlib/qt/QtWebKit.py", line 10, in <module>
    from PyQt4.QtWebKit import *  # analysis:ignore
ImportError: No module named 'PyQt4.QtWebKit'
I see some similar question here but the log error was different and the suggestion find do not help to solve the problem.
edwinksl
  • 24,109
