Ubuntu Gurus,
I have a rare configuration of 2016 MacPro6,1 with two AMD Radeon R9 280X Tahiti video cards, and three 4K monitors connected via DisplayPort / Thunderbolt ports.
The system installs successfully, but both LiveCD (for install) and installed system require "nomodeset" option, otherwise boot process hangs with a black screen.
With "nomodeset" system detects and works only on one monitor, connected via HDMI. All monitors connected via DisplayPorts remain blank.
I tried different versions of Ubuntu (14.04.4, 14.04.5, 15.10, 16.04, 16.04.1, 16.10), all have this problem, and also several versions of Linux Mint, with same result. I also tried newer upstream kernels (4.6, 4.7.3, 4.8) on Ubuntu 16.04.1, all with the same result.
But I found one distro of Linux, called KaOS (https://kaosx.us/) that works OK on my hardware. Soon after butting, it successfully detects and turns On all three monitors connected via Display Ports, and then presents normal wide KDE desktop on all three monitors.
I compared journal entries from Ubuntu and KaOS boots, and it seems that KaOS successfully detects and activates both AMD cards, and then continues to boot normally. It uses open source "radeon" driver.
Ubuntu, on the other hand (all versions and kernels listed above), with the same "radeon" driver detects only the first card, and fails on the second card, which causes immediate shutdown of "radeon" driver, and boot process hangs after that.
Here's the relevant messages from the journals. Full journal logs are available in the attachments.
KaOS:
First card:
[drm] radeon kernel modesetting enabled.
[drm] initializing kernel modesetting (TAHITI 0x1002:0x6798 0x106B:0x0128 0x00).
[drm] register mmio base: 0xA0700000
[drm] register mmio size: 262144
[drm] ACPI VFCT contains a BIOS for 02:00.0 1002:6798, size 65536
[drm:radeon_get_bios] ATOMBIOS detected
ATOM BIOS: Tahiti
[drm] Loading tahiti Microcode
[drm] Initialized radeon 2.45.0 20080528 for 0000:02:00.0 on minor 0
fb: switching to radeondrmfb from EFI VGA
Second card:
[drm] ACPI VFCT table is not for this card
radeon 0000:06:00.0: Invalid PCI ROM header signature: expecting 0xaa55, got 0x0000
ATOM BIOS: Tahiti
[drm] radeon: dpm initialized
[drm] Initialized radeon 2.45.0 20080528 for 0000:06:00.0 on minor 1
(Notice these "Invalid PCI ROM header signature" errors, but the card initialized successfully despite them, and KaOS developers confirmed, that these errors are normal for ATI cards, and are harmless)
Ubuntu:
First card:
[drm] initializing kernel modesetting (TAHITI 0x1002:0x6798 0x106B:0x0128).
ATOM BIOS: Tahiti
[drm] Initialized radeon 2.43.0 20080528 for 0000:02:00.0 on minor 0
Second card:
[drm] initializing kernel modesetting (TAHITI 0x1002:0x6798 0x106B:0x0127).
[drm] register mmio base: 0xA0600000
radeon 0000:06:00.0: Invalid ROM contents
[drm:radeon_get_bios [radeon]] *ERROR* Unable to locate a BIOS ROM
radeon 0000:06:00.0: Fatal error during GPU init
[drm] radeon: finishing device.
radeon: probe of 0000:06:00.0 failed with error -22
Notice same errors "Invalid ROM contents" (slightly different messages, but I have checked in sources that they mean the same - unexpected ROM signature) After these errors radeon/drm driver fails with ERROR Unable to locate a BIOS ROM, and then "finishing device."
KaOS uses newer kernel 4.7.3-1, but I tried 4.6, 4.7.3, 4.8 on Ubuntu, without success.
Another thing I noticed from journals: on KaOS udev rules are loaded before kernel modesetting, but on Ubuntu - after modesetting. Can this be a reason?
Graphics cards info:
lspci | grep VGA
02:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Tahiti XT [Radeon HD 7970/8970 OEM / R9 280X]
06:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Tahiti XT [Radeon HD 7970/8970 OEM / R9 280X]
Full "lspci -vvv" and "lshw" outputs are also attached for completeness.
I really need to make this workstation work under Linux, don't want to settle for MacOS.
If somebody competent could have a look at this and give some suggestions, I'd appreciate it a lot.
Thanks, Heigh
Update of 08-Nov-2016:
Hi Nick,
Thank you for the reply, I will try radeon.pm=0 option.
But I have found a workaround or solution that worked for me, and may also work for you.
The system needs to be booted with systemd-boot bootloader (or perhaps any other supporting UEFI boot)
When I boot Ubuntu on my MacPro with standard, installed during installation grub2, radeon driver would't detect external displays connected via Display Ports.
But when I boot system using systemd-boot installed by Arch Linux (or KaOS), it detects displays normally, and works correctly, supporting all external displays as expected.
I think this is related to some aspects of the hardware not being exposed in BIOS boot mode, and exposed in EFI/UEFI boot mode.
Preferred solution would be working radeon driver in BIOS mode if possible, or, if that is not possible, some meaningful message in the system journal explaining that certain features (e.g. external monitors via Display Port) will not be supported unless the system is booted in EFI/UEFI mode.
I submitted a bug into radeon bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=98523
Hopefully, this will be fixed to work out of the box at some point.
Thank you, Heigh
One issue I've seen reported is the radeon power management (you can turn that off in grub with radeon.pm=0) that apparently shuts down the 2nd gpu on boot.
I'm running the basic radeon drivers with two D700. It only works with one displayport display.
I'm trying to get my two D700 to work with multiple displays, with no luck so far.
Andrew
