I have Windows 7 x64 bits on my TravelMate P446-M laptop. The laptop comes with HDD that is already partitioned into two NTFS partitions around 250 GBytes and one hidden partition for recovery. I installed Ubuntu LTS 16.04 using Flash Memory. During the installation, I re-partitioned the second 250 Gbytes partition into the following three partitions:
  1. 50 Gbytes to mount the root '/' as ext4
  2. 190 Gbytes to mount '/home' as ext4.
  3. A partition for swap around 12 Gbytes.
I selected the place of the boot loader to be the whole hard-disk i.e. did not specify any partition. After I finished the installation, I am not able to find Ubuntu in the boot menu not even in the boot tab of the msconfig in Windows. I tried the boot-repair tool on live Ubuntu on the Flash Memory but nothing changed.
root@ubuntu:/home/ubuntu# parted --list
Model: ATA WDC WD5000LPLX-2 (scsi)
Disk /dev/sda: 500GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number  Start   End    Size    File system     Name                          Flags
 1      1049kB  106MB  105MB   fat32           EFI system partition          boot, esp
 2      106MB   123MB  16.8MB                  Microsoft reserved partition  msftres
 3      123MB   231GB  231GB   ntfs            Basic data partition          msftdata
 4      231GB   232GB  524MB   ntfs            Basic data partition          hidden, diag
 5      232GB   282GB  50.0GB  ext4
 7      282GB   453GB  171GB   ext4
 8      453GB   464GB  11.0GB  linux-swap(v1)
 6      464GB   500GB  36.3GB  ntfs            Basic data partition          hidden, diag
Model: JetFlash TS2GJFV30 (scsi)
Disk /dev/sdb: 2032MB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type     File system  Flags
 1      1049kB  2032MB  2031MB  primary  fat32        boot, lba
Here is the output of sudo efibootmgr -v:
ubuntu@ubuntu:~$ sudo efibootmgr -v
BootCurrent: 0002
Timeout: 0 seconds
BootOrder: 2001,0001,2002,2003
Boot0000* Unknown Device:   HD(1,GPT,61f0988b-288d-4d52-b004-c4d38f79d407,0x800,0x32000)/File(\EFI\ubuntu\shimx64.efi)RC
Boot0001* Windows Boot Manager  HD(1,GPT,61f0988b-288d-4d52-b004-c4d38f79d407,0x800,0x32000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)RC
Boot0002* USB HDD: JetFlashTS2GJFV30    PciRoot(0x0)/Pci(0x1d,0x0)/USB(0,0)/USB(3,0)/HD(1,MBR,0x75,0x800,0x3c8800)RC
Boot0003* Unknown Device:   HD(1,GPT,61f0988b-288d-4d52-b004-c4d38f79d407,0x800,0x32000)/File(\EFI\ubuntu\shimx64.efi)RC
Boot0004* Unknown Device:   HD(1,GPT,61f0988b-288d-4d52-b004-c4d38f79d407,0x800,0x32000)/File(\EFI\ubuntu\shimx64.efi)RC
Boot0005* Unknown Device:   HD(1,GPT,61f0988b-288d-4d52-b004-c4d38f79d407,0x800,0x32000)/File(\EFI\ubuntu\shimx64.efi)RC
Boot2001* EFI USB Device    RC
Boot2002* EFI DVD/CDROM RC
Boot2003* EFI Network   RC
IoT
  • 181
Your partition table looks OK, and your EFI System Partition (ESP) has boot loaders for both Windows and Ubuntu. Your Boot Repair output, though, lacks information from sudo efibootmgr -v, which reveals the computer's NVRAM boot manager entries. My suspicion is that your firmware is defective and is forgetting or ignoring these entries. This is a problem that crops up repeatedly, particularly with some brands. See, for instance:
Rod Smith
  • 45,120
  • 66
  • 108
I managed eventually to fix the problem. I did a clean installation of Windows 10 x64 having UEFI boot mode and secure boot disabled. Then, I installed Linux Ubuntu 16.04.1. Finally, in Windows I run the following command in the command promt:
bcdedit /set {bootmgr} path \EFI\ubuntu\grubx64.efi
After that I started to see the Grub Boot Menu and be able to select Ubuntu or Windows. However, for the original settings with Windows 7 x64 with boot legacy mode and Ubuntu 16.04.1, I was not able to show the Grub Menu.
IoT
  • 181
