A friend tried to reinstall the graphics drivers on his Ubuntu 16.04 computer (upgraded from 14.04 some 3 or 4 months ago) and now is stuck in an endless login loop. I have spent nearly 1.5 hours trying most of the commands proposed in multiple of the answers in this one and a couple others to no avail.
Here is .xsession-errors
openConnection: connect: No such file or directory
cannot connect to brltty at :0
upstart: gnome-session (Unity) main process (2094) terminated with status 1
upstart: Disconnected from notified D-Bus bus
upstart: logrotate main process (1919) killed by TERM signal
upstart: update-notifier-crash (/var/crash/_sbin_upstart.104.crash) main process
 (1983) killed by TERM signal
upstart: update-notifier-crash (/var/crash/_usr_lib_xorg_Xorg.0.crash) main proc
ess (1984) killed by TERM signal
upstart: bamfdaemon main process (2047) killed by TERM signal
upstart: hud main process (2061) killed by TERM signal
upstart: unity7 pre-start process (2065) terminated with status 143
upstart: indicator-bluetooth main process (2106) killed by TERM signal
upstart: indicator-power main process (2107) killed by TERM signal
upstart: indicator-datetime main process (2111) killed by TERM signal
upstart: indicator-sound main process (2116) killed by TERM signal
upstart: indicator-printers main process (2119) killed by TERM signal
upstart: indicator-session main process (2120) killed by TERM signal
upstart: indicator-application main process (2138) terminated with status 1
upstart: unity-panel-service main process (2098) killed by TERM signal
It is likely this may be an issue encountered by someone else before but, with so many other similar questions/answers, it has been hard to find something that would work.
At this point I think I would have spent less time if from the beginning I had re-installed the whole OS.
Graphics card: AMD Radeon HD 6350 512mb
Juan Antonio
  • 1,602
Try starting Ubuntu in recovery mode.
First, Connect an ethernet cable and manually configure a network connection: https://help.ubuntu.com/community/NetworkConfigurationCommandLine/Automatic
Make sure that you have an internet connection:
ping -c 4 google.com
From there, remove amd and nvidia drivers:
sudo apt-get remove --purge xorg-driver-fglrx fglrx* nvidia* nouveau xserver-xorg-video-ati
This should remove amd and nvidia video drivers.
Install the open source video driver:
(Proprietary drivers can be installed later)
Intel: no action needed
AMD: sudo apt-get install xserver-xorg-video-ati
Nvidia: sudo apt-get install nouveau
Reconfigure x:
sudo apt-get install build-essential cdbs fakeroot dh-make debhelper debconf libstdc++6 dkms libqtgui4 wget execstack libelfg0 dh-modaliases
sudo apt-get install --reinstall libgl1-mesa-glx libgl1-mesa-dri
sudo mv /etc/X11/xorg.conf /etc/X11/xorg.conf.old
sudo dpkg-reconfigure xserver-xorg
Update and fix broken dependencies:
sudo apt-get update && sudo apt-get upgrade && sudo apt-get autoremove && sudo apt-get check
Now reboot:
sudo reboot now
Your system should be back up now. To install the proprietary driver or for other gpu chips, go here for instructions: https://help.ubuntu.com/community/BinaryDriverHowto
