My problem is short. I have typed
chown -R root:root /var
and my mysql server stopped working :/ I tried searching for the solution, but nothing helped me.
I have also problem with permissions in Phpmyadmin. Errors you can found here.
I know, that i have ruined the whole structure of ownerhsip, so if you have a list of default users and groups in var I would be very gratefull.
That command was harmful. It changed the ownership of all objects (file and directories) inside /var directory to root user. But that is not what some programs expect, including mysql
mysql wants the files inside /var/lib/mysql directory to be owned by the user mysql.
So, you should change the ownership of the directory (recursively) again using this command
sudo chown -R mysql:mysql /var/lib/mysql
Except this file /var/lib/mysql/debian-5.7.flag. That one is owned by root. After executing the above command, you can again change the ownership of this file
sudo chown root:root /var/lib/mysql/debian-5.7.flag
Also mysql wants the its log directory to be owned by mysql user. So, do this again to change ownership of that too
sudo chown -R mysql:mysql /var/log/mysql
Fortuantely, I had phpmyadmin installed. I can give the files list owned by mysql in /var/lib/phpmyadmin directory. Here is the list. Change ownership of all of these using sudo chown mysql:mysql filename command.
/var/lib/mysql/phpmyadmin
/var/lib/mysql/phpmyadmin/pma__table_uiprefs.ibd
/var/lib/mysql/phpmyadmin/pma__bookmark.frm
/var/lib/mysql/phpmyadmin/pma__pdf_pages.ibd
/var/lib/mysql/phpmyadmin/pma__usergroups.ibd
/var/lib/mysql/phpmyadmin/pma__savedsearches.ibd
/var/lib/mysql/phpmyadmin/pma__designer_settings.ibd
/var/lib/mysql/phpmyadmin/pma__relation.ibd
/var/lib/mysql/phpmyadmin/pma__export_templates.ibd
/var/lib/mysql/phpmyadmin/pma__favorite.frm
/var/lib/mysql/phpmyadmin/pma__column_info.ibd
/var/lib/mysql/phpmyadmin/pma__userconfig.ibd
/var/lib/mysql/phpmyadmin/pma__users.frm
/var/lib/mysql/phpmyadmin/pma__relation.frm
/var/lib/mysql/phpmyadmin/pma__table_coords.frm
/var/lib/mysql/phpmyadmin/pma__navigationhiding.frm
/var/lib/mysql/phpmyadmin/pma__column_info.frm
/var/lib/mysql/phpmyadmin/pma__history.frm
/var/lib/mysql/phpmyadmin/pma__userconfig.frm
/var/lib/mysql/phpmyadmin/pma__tracking.frm
/var/lib/mysql/phpmyadmin/pma__export_templates.frm
/var/lib/mysql/phpmyadmin/pma__users.ibd
/var/lib/mysql/phpmyadmin/pma__table_coords.ibd
/var/lib/mysql/phpmyadmin/pma__table_info.ibd
/var/lib/mysql/phpmyadmin/pma__table_info.frm
/var/lib/mysql/phpmyadmin/pma__savedsearches.frm
/var/lib/mysql/phpmyadmin/pma__central_columns.frm
/var/lib/mysql/phpmyadmin/pma__central_columns.ibd
/var/lib/mysql/phpmyadmin/pma__history.ibd
/var/lib/mysql/phpmyadmin/pma__favorite.ibd
/var/lib/mysql/phpmyadmin/pma__table_uiprefs.frm
/var/lib/mysql/phpmyadmin/pma__recent.ibd
/var/lib/mysql/phpmyadmin/pma__usergroups.frm
/var/lib/mysql/phpmyadmin/pma__navigationhiding.ibd
/var/lib/mysql/phpmyadmin/pma__bookmark.ibd
/var/lib/mysql/phpmyadmin/pma__designer_settings.frm
/var/lib/mysql/phpmyadmin/pma__tracking.ibd
/var/lib/mysql/phpmyadmin/pma__pdf_pages.frm
/var/lib/mysql/phpmyadmin/pma__recent.frm
/var/lib/mysql/phpmyadmin/db.opt
I've answered this to fix only mysql related stuff. But if you need to fix all those, you can check these questions
Anwar
  • 77,855
