How can I import a PST from Windows 2007 into Ubuntu 11.10's Evolution 3.2.1?
Asked
Active
Viewed 2.2k times
12
readpst: This software will allow you to convert all your .pst MS Outlook files into .mbox files. These .mbox files can then be imported into Evolution using its Import feature.
To install the readpst program in 11.10:
sudo apt-get install readpst
Sample command (assuming that you have a dual-core processor, you can run this task in parallel using the -j switch):
mkdir ~/Evolution
readpst -D -j 2 -o ~/Evolution -q -r ~/outlook.pst
You will need to change the paths to where you want to save the files and where you have saved your original .pst file.
After this, start Evolution and use the import feature to import these .mbox files, one-by-one.
rigved
- 2,377
While @rigved has the correct answer, I'm writing this for those who may not use Ubuntu and need a bit of extra help. I use Gentoo, so this is how I installed readpst:
- Install
gnome-extra/libgsf(a gnome dependency, I use KDE) - Download libpst from https://www.five-ten-sg.com/libpst/packages/. I used
libpst-0.6.75 ./configure,sudo makeandsudo make install
NuclearPeon
- 446
- 4
- 8
