OS: Ubuntu 16.04
I have installed genymotion-2.8.0-linux_x64 on my Ubuntu 16.04, with virtualbox version 5.1.8. when launching the emulator, there is no voice at all. I tried to change android version or the device type with no luck. Can anyone give a hint, where is the problem?
M. Dev
  • 91
It might be problem with VirtualBox configuration. If so, changing the "Host Audio Driver" to "Pulseaudio" may fix it.
Check the answer at Genymotion android emulator sound problem on the Linux Mint Forums. As Jamkirk wrote in this post:
I have the exact same setup as you and fixed this by going in to the Oracle VM Virtualbox settings for the VM that Genymotion creates. Go to Settings -> Audio -> Host Audio Driver and change it to PulseAudio.
It still crackles sometimes but its a big improvement
Eliah Kagan
  • 119,640
