I'm on 14.04.5 LTS. I get this error when running a normal apt-get upgrade:
Setting up nginx-common (1.10.1-3+trusty1) ...
dpkg: error processing package nginx-common (--configure):
 subprocess installed post-installation script returned error exit status 1
I've omitted all the subsequent errors caused by this, "Package nginx-common is not configured yet.", etc.
I followed the process in this answer to debug the .postinst and it never gets beyond the 3rd line: . /usr/share/debconf/confmodule – that's what's returning the 1.
I've tried this solution but it didn't help, debconf is definitely accessible. And these ones (the error persists). I have no ipv6 listen directives in any included conf files as far as I can tell.
I have no clue as to how I'd debug debconf to see why it's failing. Does anyone know what I should try next?
Edit: New updates, they install but I get this error at the end:
Setting up nginx-full (1.10.1-3+trusty2) ...
initctl: invalid command: upgrade
Try `initctl --help' for more information.
invoke-rc.d: initscript nginx, action "upgrade" failed.
Not sure if I should mark as resolved.
Walf
  • 452
This specific issue is fixed, please update your packages!
Ubuntu Repositories (LP Bug #1637058)
In Ubuntu Zesty's proposed repository (this is an in-development release, I hope you aren't using this...), 1.10.1-0ubuntu5 addresses this issue.
In Ubuntu Trusty, Xenial, and Yakkety, the Security team has released updated versions of the packages to address this issue, and is considering it a regression in the package. This information is detailed in the bug and very briefly in the corresponding Ubuntu Security Notice (USN-3114-2), but this issue is fixed in the following versions of the package:
  • Ubuntu Trusty: 1.4.6-1ubuntu3.7 (Security and Updates repositories)
  • Ubuntu Xenial: 1.10.0-0ubuntu0.16.04.4 (Security and Updates repositories)
  • Ubuntu Yakkety: 1.10.1-0ubuntu1.2 (Security and Updates repositories)
The version in the Ubuntu Precise repositories are not affected, as they were never altered in a way which introduced the CVE which prompted the recent updates. (This only applies to the Ubuntu Repositories, not the PPAs.)
PPAs (LP Bug #1637200)
I have uploaded revised packages to the staging PPA that address this issue, and implement a fix. These built without issue, and were copied to the primary Mainline and Stable PPAs on Launchpad as of 12:56 PM on October 27, 2016 (UTC-04:00).
This includes fixes for Precise, Trusty, Xenial, and Yakkety. The PPAs do not yet have Zesty support.
Obligatory disclosure:
I am the primary person on the Ubuntu Server Team in charge of the nginx packages. I also maintain the PPAs that reside under the team at https://launchpad.net/~nginx.
I also have direct knowledge on this issue, and the process of fixes being made available, because I helped to discover the problem affects the recent Security updates done, and also Debian.
Thomas Ward
  • 78,878
Official fixed packages have been released, use those
TL;DR Scroll to the bottom
Just ran into this issue myself.
To debug it a bit further, I set the following environment variable:
export DEBCONF_DEBUG=developer
That way we can see what debconf is doing.
Now we run
dpkg --configure --pending
And we can see the following:
 Setting up nginx-common (1.10.1-3+xenial1) ...
 debconf (developer): frontend started
 debconf (developer): frontend running, package name is nginx-common
 debconf (developer): starting /var/lib/dpkg/info/nginx-common.config configure 1.10.1-3+xenial0
 dpkg: dependency problems prevent configuration of libnginx-mod-http-image-filter:
 libnginx-mod-http-image-filter depends on nginx-common (= 1.10.1-3+xenial1); however:
Now we can edit the /var/lib/dpkg/info/nginx-common.config script, and change
#!/bin/sh
with
#!/bin/sh -x to enable debugging as well.
Running dpkg --configure --pending again will show:
+ set -e
+ . /usr/share/debconf/confmodule
+ [ ! 1 ]
+ [ -z  ]
+ exec
+ exec
+ DEBCONF_REDIR=1
+ export DEBCONF_REDIR
+ logdir=/var/log/nginx
+ log_symlinks_check 1.10.1-3+xenial0
+ [ -z 1.10.1-3+xenial0 ]
+ dpkg --compare-versions 1.10.1-3+xenial0 lt-nl 1.10.1-0ubuntu1.1
+ return
And now we can see our problematic line in the script
returns exit code 1, as it should -- it's doing a version comparison and returns 0 or 1 depending on the result.
I won't comment on how to properly fix it, as it's an actual bug being tracked at #1637058 (for Ubuntu) and #1637200 (for PPAs) at LP.
Work-around fix:
Edit /var/lib/dpkg/info/nginx-common.config
and add a return on the first line of the log_symlinks_check function.
e.g.:
 log_symlinks_check() {
     return                <---- here
     # Skip new installations
     [ -z "$1" ] && return
This will allow the upgrade process to continue.
EDIT As pointed out by @Thomas Ward, this will skip a setup step (fixing insecure symlinks -- if there are any -- in /var/log/nginx)
Having same issue on :
  • 14.04.5 LTS (GNU/Linux 3.13.0-32-generic x86_64)
  • 16.04.1 LTS (GNU/Linux 4.4.0-45-generic x86_64)
Setting up nginx-common (1.10.1-3+trusty1) ... dpkg: error processing package nginx-common (--configure): subprocess installed post-installation script returned error exit status 1 dpkg: dependency problems prevent configuration of libnginx-mod-http-auth-pam: libnginx-mod-http-auth-pam depends on nginx-common (= 1.10.1-3+trusty1); however: Package nginx-common is not configured yet.
dpkg: error processing package libnginx-mod-http-auth-pam (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libnginx-mod-http-echo: libnginx-mod-http-echo depends on nginx-common (= 1.10.1-3+trusty1); however: Package nginx-common is not configured yet.
dpkg: error processing package libnginx-mod-http-echo (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: nginx-common libnginx-mod-http-auth-pam libnginx-mod-http-echo
Solved
I was able to fix the issue by first making a backup of the /etc/nginx folder.
sudo tar -zcf ~/nginx.tgz /etc/nginx
Then I purged anything to do with nginx from the system. I had to do it in step as the dependency issues were triggered.
sudo apt-get purge nginx-full
sudo apt-get purge nginx-common
sudo apt-get purge nginx*
After that, install nginx back onto the system sudo apt-get install nginx-full.
And finally restore the /etc/nginx folder with sudo tar -zxf ~/nginx.tgz and restart nginx using sudo service nginx restart
Hope this helps!
