Context
I have spend some time solving this and now I am stuck. When I inspect output of lspci, I find that I have two possible VGA controlers:
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09) (prog-if 00 [VGA controller])
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Whistler [Radeon HD 6730M/6770M/7690M XT] (rev ff) (prog-if ff)
Only the default Intel processor graphics seem to be chosen now. This is also confirmed by running lshw -c display, which gives:
*-display
description: VGA compatible controller
product: 2nd Generation Core Processor Family Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:36 memory:c0000000-c03fffff memory:b0000000-bfffffff ioport:6000(size=64)
Now to the problem
This is why I decided to try and create custom xorg.conf file in the system in order to be able to asign the graphics card to the display directly. But, when I start Ubuntu with this file in /usr/share/X11/xorg.conf.d, I get an error which I do not know how to resolve.
The contents of the file are:
Section "ServerLayout"
Identifier "amd-layout"
Screen 0 "amd-screen" 0 0
EndSection
Section "Device"
Identifier "amd-device"
Driver "radeon"
BusID "PCI:1:0:0"
EndSection
Section "Device"
Identifier "intel"
Driver "intel"
Option "AccelMethod" "uxa"
BusID "PCI:0@0:2:0"
EndSection
Section "Monitor"
Identifier "amd-monitor"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
Option "DPMS" "true"
EndSection
Section "Screen"
Identifier "amd-screen"
Device "amd-device"
GPUDevice "intel"
Monitor "amd-monitor"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 24
EndSubSection
EndSection
The reading from /var/log/Xorg.0.log of the error is:
[ 41.323] (EE) Screen(s) found, but none have a usable configuration.
[ 41.323] (EE)
Fatal server error:
[ 41.323] (EE) no screens found(EE)
[ 41.323] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 41.323] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 41.323] (EE)
[ 41.326] (EE) Server terminated with error (1). Closing log file.
I have a feeling that I probably messed up when creating the xorg.conf file, but I do not know where? Do you see a mistake there?
