I'm aware of the implications of running tomcat on port 80, but I'm after a quick solution. I'm trying to follow this tutorial. I've followed the tutorial with two changes:
  • tomcat6 is user name tomcat is run as
  • The location of tomcat conf file: /usr/share/tomcat6/bin/catalina.sh
But I'm still getting permissions errors. Java is saying its unable to bind to port 80. What else should i be doing? What other information should i provide for people to debug? Just to confirm, there's nothing else running on port 80
richzilla
  • 12,185
You can change AUTOBIND property of /etc/default/tomcat6 to "yes" as follows:
AUTHBIND=yes
Restart your tomcat and that will enable you to use available privileged port (1-1023).
Eliah Kagan
  • 119,640
Avikar
  • 161
There are two different ways of doing this without actually touching the tomcat config.
You can make an iptables script that redirects traffic from port 80 to port 8080 (then you dont need to fiddle around with tomcat settings)
for iptables
iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 8080 -j REDIRECT --to-port 80 would do the trick! (make a script so its done automatically on uppstart
or you can create a Apache reverse proxy that actually proxies the connections to your tomcatserver through it (this is good since it can actually cache request and speed up connections for you)
tomodachi
  • 15,370
Start tomcat services using authbind this will allow user to start ports less than 1024 we do not need to redirect or iptables.
apt-get install authbind -y
To install Authbind software
chmod -R 755 /etc/authbind
group should be user group.
chown -Rh root:group /etc/authbind
After that run the below commands
cd /etc/authbind/byuid
As an example lets imagne user id is 2000 you can use your user id number
echo '0.0.0.0/0:1,1023' > 2000
That file should be own by user and group.
chown : 2000
chmod 700 2000
Add the below line in tomcat startup file $CATALINA_BASE/startup.sh
export JAVA_OPTS="$JAVA_OPTS -Djava.net.preferIPv4Stack=true"
For Starting tomcat using Authbind service startup.sh
Comment the below line
#$CATALINA_HOME/bin/startup.sh
Add This End as the end of the file
AUTHBIND_COMMAND="/usr/bin/authbind --deep /bin/bash -c "
$AUTHBIND_COMMAND $CATALINA_HOME/bin/startup.sh
now you should be able to start tomcat services as user with less that 1024 ports.
PKumar
  • 3,182
In the Tomcat HTTP connector, make sure your connector on port 80 is binding to ALL interfaces, or 0.0.0.0 , rather than just 127.1 . That might explain why your not able to connect with a url such as http://10.0.0.2:80 but you can with http://127.1:80
djangofan
  • 3,874
