After re-installing Ubuntu 16.04 on my laptop (Lenovo G575) there are no win10 loading option in grub boot menu. There are some info i got:
Boot Info Script cfd9efe + Boot-Repair extra info [Boot-Info 26Apr2016]
============================= Boot Info Summary: ===============================
=> Grub2 (v2.00) is installed in the MBR of /dev/sda and looks at sector 1 of the same hard drive for core.img. core.img is at this location and looks for (,msdos6)/boot/grub. It also embeds following components:
modules
fshelp ext2 part_msdos biosdisk
sda1: __________________________________________________________________________
File system:       Extended Partition
Boot sector type:  -
Boot sector info:
sda5: __________________________________________________________________________
File system:       swap
Boot sector type:  -
Boot sector info:
sda6: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:  Ubuntu 16.04.1 LTS
Boot files:        /boot/grub/grub.cfg /etc/fstab
                   /boot/grub/i386-pc/core.img
sda2: __________________________________________________________________________
File system:       ntfs
Boot sector type:  Windows 7/2008: NTFS
Boot sector info:  No errors found in the Boot Parameter Block.
Operating System:
Boot files:        /bootmgr /Windows/System32/winload.exe
* =================== Suggested repair The default repair of the Boot-Repair utility would purge (in order to) and reinstall the grub2 of sda6 into the MBR of sda. Additional repair would be performed: unhide-bootmenu-10s fix-windows-boot
=================== Final advice in case of suggested repair
The boot files of [The OS now in use - Ubuntu 16.04.1 LTS] are far from the start of the disk. Your BIOS may not detect them. You may want to retry after creating a /boot partition (EXT4, >200MB, start of the disk). This can be performed via tools such as gParted. Then select this partition via the [Separate /boot partition:] option of [Boot Repair]. (https://help.ubuntu.com/community/BootPartition)
I dont know what to do now. Help please.
