I just format my root partition (and keep my Home partition), and reinstalled Ubuntu 10.10. But the theme of macbuntu is still there.
If I try to run it's "uninstall.sh" even with "--force" I get "The script is not able to determine what version is currently installed" (the version is 10.10).
By the way, I also deleted ".macbuntu" from my Home directory, but I'm still not able to uninstall it.
Any hint?
Student
  • 12,236
macbuntu cannot determine the currently installed version probably because you deleted the ~/.macbuntu folder.
To still uninstall macbuntu, you need to tweak the uninstall script so it will omit the checks in the files:
  1. Back up your home directory (please really do that!):
    sudo cp -r ~ /home/backup
  2. Open the uninstall script uninstall.sh and comment the following lines (put a # in front of them):
    chk_version
    chk_user
  3. Run the uninstall script uninstall.sh. Cross fingers ;)
If it is a GTK+ theme, then it would have left some files in ~/.themes, possibly also in ~/.icons and others.
To be certain, you can manually open the uninstall script, look for all folders that are marked for removal, and manually clean these up your self.
RolandiXor
  • 51,797
