nazar@android:~$ sudo dpkg -i wps*amd64.deb
[sudo] password for nazar:
Selecting previously unselected package wps-office.
(Reading database ... 227014 files and directories currently installed.)
Preparing to unpack wps-office_10.1.0.5672-a21_amd64.deb ...
Unpacking wps-office (10.1.0.5672~a21) ...
dpkg: dependency problems prevent configuration of wps-office:
wps-office depends on libpng12-0; however:
Package libpng12-0 is not installed.
dpkg: error processing package wps-office (--install):
dependency problems - leaving unconfigured
Processing triggers for desktop-file-utils (0.23-1ubuntu1) ...
Processing triggers for mime-support (3.60ubuntu1) ...
Processing triggers for shared-mime-info (1.7-1) ...
Unknown media type in type 'all/all'
Unknown media type in type 'all/allfiles'
Processing triggers for hicolor-icon-theme (0.15-1) ...
wps-office
nazar@android:~$ sudo apt-get install libpng12-0
Reading package lists... Done
Building dependency tree
Package libpng12-0 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libpng12-0' has no installation candidate
nazar@android:~$ sudo apt install -f
Correcting dependencies... Done
The following packages will be REMOVED:
wps-office
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 367 MB disk space will be freed.
Do you want to continue? [Y/n] n
Abort.
nazar@android:~$
Asked
Active
Viewed 1.5k times
nazar2sfive
- 1,493
10
Download libpng12-0_1.2.50-2+deb8u2_amd64.deb. If you use a 32 bit system, download the 32 bit deb file.
Install the package and then install wps-office.
