I am using Ubuntu 16.04 LTS. This morning when I ran sudo apt-get update, I encountered the following error:
W: The repository 'http://us.archive.ubuntu.com/ubuntu lucid Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/lucid/main/source/Sources 404 Not Found [IP: 91.189.91.26 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
I've checked the internet for an answer. Although I did find a few similar posts, none of the solution works for me. One of the interesting solution I tried was:
The simplest solution is to do the following two steps:
1- Backup your sources list -> sudo cp /etc/apt/sources.list /etc/apt/sources.list.backup
2- Open the sources file "/etc/apt/sources.list" Rename all the instances of us.archive or archive in http://us.archive.ubuntu.com/ubuntu/ to
http://old-releases.ubuntu.com/ubuntu/
Also do the same for the http://security.ubuntu.com/ubuntu/dists/saucy-security/universe/binary-i386/Packages
3- Run sudo apt-get update after doing the above.
Guess what.. didn't work. Infact it threw more errors:
W: The repository 'http://old-releases.ubuntu.com/ubuntu xenial Release' does not have a Release file.
W: The repository 'http://old-releases.ubuntu.com/ubuntu xenial-updates Release' does not have a Release file.
W: The repository 'http://old-releases.ubuntu.com/ubuntu xenial-backports Release' does not have a Release file.
W: The repository 'http://old-releases.ubuntu.com/ubuntu xenial-security Release' does not have a Release file.
E: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/xenial/main/binary-amd64/Packages 404 Not Found
E: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-amd64/Packages 404 Not Found
E: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/xenial-backports/main/binary-amd64/Packages 404 Not Found
E: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/xenial-security/main/binary-amd64/Packages 404 Not Found
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/lucid/main/source/Sources 404 Not Found [IP: 91.189.91.23 80]
Please help.
EDIT:
Here is my original sources.list:
# deb cdrom:[Ubuntu 16.04 LTS _Xenial Xerus_ - Release amd64 (20160420.1)]/ xenial main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://in.archive.ubuntu.com/ubuntu/ xenial main restricted
# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://in.archive.ubuntu.com/ubuntu/ xenial-updates main restricted
# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team.
deb http://in.archive.ubuntu.com/ubuntu/ xenial universe
# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial universe
deb http://in.archive.ubuntu.com/ubuntu/ xenial-updates universe
# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial-updates universe
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://in.archive.ubuntu.com/ubuntu/ xenial multiverse
# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial multiverse
deb http://in.archive.ubuntu.com/ubuntu/ xenial-updates multiverse
# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://in.archive.ubuntu.com/ubuntu/ xenial-backports main restricted universe multiverse
# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu xenial partner
# deb-src http://archive.canonical.com/ubuntu xenial partner
deb http://security.ubuntu.com/ubuntu xenial-security main restricted
# deb-src http://security.ubuntu.com/ubuntu xenial-security main restricted
deb http://security.ubuntu.com/ubuntu xenial-security universe
# deb-src http://security.ubuntu.com/ubuntu xenial-security universe
deb http://security.ubuntu.com/ubuntu xenial-security multiverse
# deb-src http://security.ubuntu.com/ubuntu xenial-security multiverse
