The xclip manual says that there are three storage locations named primary (XA_PRIMARY), secondary (XA_SECONDARY) and clipboard (XA_CLIPBOARD). I copied (Ctrl+c) some text from my browser and examined the contents of the three locations mentioned above in the terminal:
xclip -s primary -o
xclip -s secondary -o
xclip -s clipboard -o
All three contain the same text.
If I now type
date | xclip -selection XA_PRIMARY
Only the XA_PRIMARY should contain the date text. But in fact the other two i.e. XA_SECONDARY, and XA_CLIPBOARD also contain the same text (date information). So are the three one and the same? And if so what is the point?
What baffled me even more, Ctrl+Shift+v (still in terminal mode) pastes the orgiginal text that I copied from the browser! which suggests that shell's own clipboard is in operation as well.
Does someone have an example that demonstarates that the three locations can hold different values at the same time and how they relate to the regular clipboard?
Unfortunately xclip silently ignores invalid command line options:
There is no -s option as both -selection and -silent start with -s. You have to use at least -se.
As xclip just ignores your -s option the commands
xclip -s primary -o
xclip -s asdfghj -o
all just use the default selection (primary).
For the selection name only the first character is actually used, and if it is anything but s or c the default is used.
date | xclip -selection XA_SECONDARY
date | xclip -selection XA_CLIPBOARD
all use the primary selection.
Use something like
date | xclip -se p    # write to primary selection
xclip -se c -o        # read from clipboard
I'll address the missing point, that is "why 3 different clipboards".
  1. Historically, you could issue a command with 1 argument or with 2. First would operate on PRIMARY only, 2nd - on both PRIMARY and SECONDARY. A "switching" mechanism, if you will. Or a backup, if you really wanted to leave what you had in PRIMARY alone and untouched. Specification however wasn't followed and various apps did it in various ways.
  2. Windows / Macs popularized clipboard.
  3. This led to an interesting case: XA_PRIMARY was used for selections (as designed), rarely anybody had a good idea for XA_SECONDARY, and XA_CLIPBOARD was... like a clipboard.
xclip and xsel work on XA_PRIMARY by default, since most X-apps work this way: if you highlight a text, it is selected and therefore lands in a PRIMARY SELECTION buffer.
If you wish to paste PRIMARY, use middle mouse button or Shift+Insert. Or transfer it's contents to CLIPBOARD and just paste xclip -o | xclip -se c.
Excellent reading (now as HTML): https://specifications.freedesktop.org/clipboard-spec/1.0/
Old link, via Wayback Machine, as txt: https://web.archive.org/web/20230901182311/https://specifications.freedesktop.org/clipboards-spec/clipboards-latest.txt
