I have Gwenview installed in Ubuntu 16.10, and I was not able to play videos. The console output gives this error:
WARNING: bool Phonon::FactoryPrivate::createBackend() phonon backend plugin could not be loaded
I had tried several options around, including the installation of phonon-backends-vlc, which did not make a difference.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
After some tries, I have realised that there are separate packages for phonon qt5.
The installation of the following packages solved the issue on my system:
sudo apt install phonon4qt5 phonon4qt5-backend-gstreamer phonon4qt5-backend-vlc
Now, the installation of these packages should probably be recommended from the gwenview package, so this is probably a packaging bug.
