Ubuntu has notified me I have some updates but when trying to update I get this message...
The package system is broken: Check if you are using third party repositories. If so disable them, sine they area common source of problems. Furthermore run the following commend in a Terminal: apt-get install -f
I have followed the instructions here to disable third party repositories and I still have the same issue.
In Terminal as suggested apt-get install -f returns this...
telos182@imaLaptop:/$ sudo apt-get install -f
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following additional packages will be installed:
  libpcap0.8
The following packages will be upgraded:
  libpcap0.8
1 upgraded, 0 newly installed, 0 to remove and 61 not upgraded.
4 not fully installed or removed.
Need to get 0 B/117 kB of archives.
After this operation, 8,192 B of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 220047 files and directories currently installed.)
Preparing to unpack .../libpcap0.8_1.7.4-2_amd64.deb ...
Unpacking libpcap0.8:amd64 (1.7.4-2) over (1.4.0-2) ...
dpkg: error processing archive /var/cache/apt/archives/libpcap0.8_1.7.4-2_amd64.deb (--unpack):
 trying to overwrite shared '/usr/share/man/man7/pcap-filter.7.gz', which is different from other instances of package libpcap0.8:amd64
Processing triggers for libc-bin (2.23-0ubuntu3) ...
Processing triggers for man-db (2.7.5-1) ...
Furthermore apt-get remove gives me this...
telos182@imaLaptop:/$ sudo apt-get remove
You might want to run 'apt-get -f install' to correct these.
 libpcap0.8 : Breaks: libpcap0.8:i386 (!= 1.4.0-2) but 1.7.4-2 is installed
 libpcap0.8:i386 : Breaks: libpcap0.8 (!= 1.7.4-2) but 1.4.0-2 is installed
 libpcap0.8-dev : Depends: libpcap0.8 (= 1.7.4-2) but 1.4.0-2 is installed
 tcpdump : Depends: libpcap0.8 (>= 1.5.1) but 1.4.0-2 is installed
E: Unmet dependencies. Try using -f.
And apt-get remove -f as it suggests comes back with this...
telos182@imaLaptop:/$ sudo apt-get remove -f
 libpcap0.8
 libpcap0.8
1 upgraded, 0 newly installed, 0 to remove and 62 not upgraded.
I have a very good idea of how this all happened but sadly have not been able to address the issue :(
