I have installed Windows 7 and Ubuntu 16 and I can see both on the bootloader, however I can only start Ubuntu. If I choose Windows in the bootloader it shows an error message and then reboots the computer. It seems like the Windows link is broken on the bootloader.
$ sudo fdisk -l
Device Boot Start End Sectors Size Id Type
/dev/sda1 2048 97656344 97654297 46.6G 83 Linux
/dev/sda2 * 97656832 1949212671 1851555840 882.9G 7 HPFS/NTFS/exFAT
/dev/sda3 1949214718 1953523711 4308994 2.1G 5 Extended
/dev/sda5 1949214720 1953523711 4308992 2.1G 83 Linux
Device Start End Sectors Size Type
/dev/sdb1 2048 206847 204800 100M EFI System
/dev/sdb2 206848 468991 262144 128M Microsoft reserved
/dev/sdb3 468992 151764991 151296000 72.1G Microsoft basic data
/dev/sdb4 243890176 250068991 6178816 3G Linux swap
/dev/sdb5 151764992 243890175 92125184 44G Linux filesystem
It seems like the init is sda2 which is the partition with my Windows data, however the Windows OS is in sdb3.
The Boot Repair Boot Info Script generated these results.
I have installed boot-repair, but it says that it does not work in Legacy Mode, only in UEFI.
Also I have added these lines in /etc/grub.d/40_custom and updated grub, however these entries do not let me boot Windows 7 either:
menuentry "Windows 7aa (loader) (on /dev/sdb1)" {
insmod part_msdos
insmod ntfs
set root='(hd1,msdos1)'
chainloader +1
menuentry "Windows 7bb (loader) (on /dev/sdb3)" {
insmod part_msdos
insmod ntfs
set root='(hd1,msdos3)'
chainloader +1
What else can I try?
Also I have tried
sudo update-grub and sudo update-grub2
Updated:
Windows entries in grub show me this error "The partition does not exist, press any button to continue..." and then again the grub menu appears.
I have tried adding a new Windows entry for the Microsoft reserved partition /dev/sdb2 (hd1/msdos2) and it shows a different screen:
Boot loader Windows administrator, choose a O.S. only with Windows option, if I choose it, then the computer reboot.
