There is several ways to find what version of python you have. Here are two ways you'll get both Python 2 and Python 3 versions:
Python Specific
First just run python and python3 with the option --version
$ python --version
Python 2.7.12
$ python3 --version
Python 3.5.2
This is specific for python, but a lot of other programs use a similar method.
General for any package/program
A more general method is to see what package is installed. dpkg -l will list out all your packages, but you can specify what packages you are looking for. For just python and python3 use the following:
$ dpkg -l 'python'
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii python 2.7.11-1 amd64 interactive high-level object-oriented language
$ dpkg -l 'python3'
ii python3 3.5.1-3 amd64 interactive high-level object-oriented language
As an extra titbit. If you'd like to find all the packages that has a name starting with python, you can use wildcard character * like this:
$ dpkg -l 'python*'
That will print a lot of lines with packages.
