I am using Ubuntu 16.04lts and want to install Remastersys. Pl. show me the answer who is using it.
Elder Geek
  • 36,752
According to the www.remastersys.org
Since Remastersys was abandoned, the team formed a fork Respin. Free Software and Open Source developers working together to create a FOSS remastering or respin program.
Follow these steps to install Respin on your system
Step 1: Clone Debian and Ubuntu source code and .deb packages from git hub by executing following command. The source and .deb packages get downloaded into your present terminal working directory
git clone https://gitlab.com/remastersys/LinuxRespin
Step 2: Change the terminal working directory to where Ubuntu source and .deb package are located(LinuxRespin/ubuntu) and run the following command to install the package
sudo dpkg -i respin_1.1.0-1_all.deb
If you get any dependency errors after running the command in step 2, run the below command to fix the dependencies and install the package.
sudo apt-get install -f
note: No need to run the command in step 2 for installing the package after running the apt-get install -f command, which does two jobs of fixing dependenies and also installing the package
Zanna
  • 72,312
TejaReddy
  • 173
Download it here, and open the downloaded file with the default program, which should be the installer.
M. Becerra
  • 3,538
  • 24
  • 40
There is no current development on Remastersys. There is a fork however called Respin.
The deb files for Respin can be downloaded from the master branch here although it looks like we are still waiting for a new version for 16.04 (due to a crashing issue) A possible workaround for this can be found here.
Elder Geek
  • 36,752
