I'm installing GitLab for my work, I'm doing it on Ubuntu Server available 16.04.1 and everything is running pretty well.
The only thing I need to do now is to configure the Reply by email feature because we are interested about the concept so we want to enable it.
The good news is, on the GitLab website, there is a detailed how-to telling you how to put this in place. Basically, this feature uses Postfix and is based on Courier Mail Server (at least as I can understand). The bad news is, on this how-to, everything goes well but the really last part, about testing the final IMAP setup (i.e. Test the final setup section), fails every time.
So, when I try to retrieve the contents of the IMAP folder with the following command, as requested in the how-to:
telnet <my.server.here> 143
I get this result:
<my_name>@<my_host>:~$ telnet <ip> 143
Trying <ip>...
Connected to <ip>.
Escape character is '^]'.
* OK [CAPABILITY IMAP4rev1 UIDPLUS CHILDREN NAMESPACE THREAD=ORDEREDSUBJECT THREAD=REFERENCES SORT QUOTA IDLE ACL ACL2=UNION] Courier-IMAP ready. Copyright 1998-2011 Double Precision, Inc. See COPYING for distribution information.
a login incoming <my_cool_pwd>
* BYE Temporary problem, please try again later
Connection closed by foreign host.
I looked for several logs files, and after 4 hours of research, I'm really lost.
The contents of the /var/log/mail.err is the following:
Oct 18 17:37:23 <my_host> imapd: authdaemon: s_connect() failed: No such file or directory
Oct 18 17:37:23 <my_host> imapd: authentication error: No such file or directory
The contents of /var/log/mail.log is:
Oct 18 17:37:10 <my_host> imapd: Connection, ip=[::ffff:xxx.xxx.xxx.xxx]
Oct 18 17:37:23 <my_host> imapd: LOGIN FAILED, user=incoming, ip=[::ffff:xxx.xxx.xxx.xxx]
When I try something simple, that command below, it fails in the same way. So it seems to be related to PAM Authentication?
sudo authtest incoming <my_cool_pwd>
The output of the above command is:
ERR: authdaemon: s_connect() failed: No such file or directory
Authentication FAILED: No such file or directory
Exactly the same stuff. The thing is, I really don't know what file/directory is involved!
Any help would be really appreciated!
