There is an implementation for the Scheme programming language called STk. That's the one used in computer science video courses published by Berkley on YouTube. I want to have it on my machine as well so that I can follow their courses exactly (although I do have MIT/GNU Scheme already installed), but they, the people who maintain the STk Scheme interpreter, don't have a package version that I could install using the apt-get utility. So, I went to their website and downloaded the file STk-4.0.1.tar.gz from here. Unpacked it to /usr/local/src (I changed the ownership of the directory using the command sudo chown $USER /usr/local/src. Cded into the directory. Unpacked the tarball using this command tar -xzvf STk-4.0.1.tar.gz. Cded into the newly created directory. And now I'm trying to build the application by running the configure script:
$ ./configure
creating cache ./config.cache
checking for ranlib... ranlib
Using 'gcc' compiler
Using '-O2' compilation options
Assumming OS is LINUX
checking for gcc... gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for POSIXized ISC... no
checking how to run the C preprocessor... gcc -E
checking for X... libraries , headers
checking for dnet_ntoa in -ldnet... no
checking for dnet_ntoa in -ldnet_stub... no
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking fd_set and sys/select... yes
Multiple precision library: libgmp
Hash tables support: yes
Posix support: yes
STklos support: yes
Socket support: yes
Regexp support: yes
Process support: yes
Html support: yes
Base64 support: yes
Locale support: yes
Pixmap Images support: yes
JPEG Images support: yes
Determining options for dynamic loading for LINUX
Linux: no dynamic loading method chosen
not updating unwritable cache ./config.cache
creating ./config.status
creating Makefile
creating Utils/STk.spec
**** Configuring Src directory
checking for unistd.h... yes
checking for limits.h... yes
checking for sigaction... yes
checking for select... yes
checking for dlopen in -ldl... yes
checking for socket in -lsocket... no
checking for t_accept in -lnsl... no
checking for ANSI C header files... yes
checking for pid_t... yes
creating Makefile
**** Configuring Extensions directory
creating Makefile
creating stk-genmake
**** Configuring Stack directory
ln: failed to create symbolic link 'libstack.c': File exists
Stack library configuration
Machine type: UNKNOWN_ARCH
Low level support:
creating libstack.h
creating Makefile
**** Configuring Tcl directory
checking whether cross-compiling... no
checking for getcwd... yes
checking for opendir... yes
checking for strerror... yes
checking for strstr... yes
checking for strtol... yes
checking for tmpnam... yes
checking for waitpid... yes
checking for strerror... (cached) yes
checking for getwd... yes
checking for wait3... yes
checking for uname... yes
checking for sin... no
checking for -lieee... yes
checking dirent.h... yes
checking for errno.h... yes
checking for float.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for sys/wait.h... yes
checking for sys/time.h... yes
checking whether time.h and sys/time.h may both be included... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking for tm_zone in struct tm... yes
checking tm_tzadj in struct tm... no
checking tm_gmtoff in struct tm... yes
checking timezone variable... yes
checking proper strstr implementation... yes
checking for strtoul... yes
checking for strtod... yes
checking for strtod... (cached) yes
checking for Solaris strtod bug... ok
checking for mode_t... yes
checking for size_t... yes
checking for uid_t in sys/types.h... yes
checking for opendir... (cached) yes
checking sys_errlist... yes
checking union wait... yes
checking matherr support... yes
checking for vfork... yes
checking vfork/signal bug... ok
checking for strncasecmp... yes
checking for BSDgettimeofday... no
checking for gettimeofday... yes
checking for gettimeofday declaration... present
checking for -linet... no
checking for net/errno.h... no
checking system version (for dynamic loading)... ./configure: 1: ./configure: Syntax error: Unterminated quoted string
**** Configuring Tk directory
checking stdlib.h... yes
checking for X11 header files... checking for -lXbsd... no
checking for memmove... yes
checking whether char is unsigned... no
checking for Solaris 2.4 strtod bug... ok
updating cache ./config.cache
creating Makefile
SUMMARY
Your system is LINUX
C compiler is: gcc
Compilation options: -O2
Dynamic loading enabled: no
X11 libraries directory:
X11 headers directory:
You have chosen the following options
Posix support: yes
STklos support: yes
Socket support: yes
Regexp support: yes
Html support: yes
Jpeg Images support: yes
Base64 support: yes
Locale support: yes
If this is correct, you can just type 'make' now at your shell prompt.
Otherwise, rerun configure with proper options (see the README file for
a description of STk configure options.)
Now, I need to use the make utility to compile the application, but I can't. This is the error I get:
$ make
make Tcl
make[1]: Entering directory '/usr/local/src/STk-4.0.1/Tcl'
make[1]: *** No rule to make target 'unix'. Stop.
make[1]: Leaving directory '/usr/local/src/STk-4.0.1/Tcl'
Makefile:81: recipe for target 'tcl-dir' failed
make: *** [tcl-dir] Error 2
I'm probably doing something wrong.
