So this was the project that I received and I'm stuck half way.
In most Linux distributions (Fedora and Ubuntu included), /bin/sh is actually a symbolic link to /bin/bash. To use zsh, we need to link /bin/sh to /bin/zsh. The following instructions describe how to change the default shell to zsh:
  • login as root
  • cd /bin
  • rm sh
  • ln –s zsh sh
The system(const char *cmd) library function can be used to execute a command within a program. The way system(cmd) works is to invoke the /bin/sh program, and then let the shell program to execute cmd. Because of the shell program invoked, calling system() within a Set-UID program is extremely dangerous. This is because the actual behavior of the shell program can be affected by environment variables, such as PATH; these environment variables are under user’s control. By changing these variables, malicious users can control the behavior of the Set-UID program.
The Set-UID program below is supposed to execute the /bin/ls command; however, the programmer only uses the relative path for the ls command, rather than the absolute path:
int main()
    system("ls"); return 0;
Login as root, write this program into a file named bad_ls.c, compile it (using gcc –o bad_ls bad_ls.c) and copy the executable as a Set-UID program into /tmp with permissions 4755.
Is it a good idea to let regular users execute the /tmp/bad_ls program (owned by root) instead of /bin/ls? Describe an attack by which a regular user can manipulate the PATH environment variable in order to read the /etc/shadow file.
I have successfully changed the default shell to zsh, created the executable bad_ls, and copied it to /tmp with permission ID 4755.
This is where I'm stuck.
After running the bad_ls file, I change the PATH env Variable to point to the current directory by using the code
export PATH =.:$PATH
If I run ls -a /etc/shadow, all I get is this: /etc/shadow
I would be really thankful if you could guide me in this problem.
wjandrea
  • 14,504
The problem is this case is that system("ls") would run whichever executable named ls it finds first in the user's set PATH.
This ls does not necessarily have to list the contents of a directory. Instead it could be a script like this:
#!/bin/sh
cat /etc/shadow
Let's say you place this script somewhere in a directory below your home directory, for example /home/datashark/bin and add this to your PATH:
PATH="/home/datashark/bin:$PATH"
If you now run ls, you will not get a directory listing, instead you will receive an error message:
cat: /etc/shadow: Permission denied
But if you run bad_ls, the system("ls")-call therein will also look for a executable named ls in your PATH and find and /home/datashark/bin/ls instead of /bin/ls. As bad_ls runs with elevated root permissions, the script named ls will (on certain systems - see below) also run with elevated root permissions and so will the command cat /etc/shadow, which will print the contents of /etc/shadow.
So it is a bad idea for root to let normal users run bad_ls as long as it has SUID privileges, because it would run any program named ls that comes first in the user's PATH.
Note:
This does not work on every Linux system. For example, it will not, according to man 3 system, work on systems where /bin/sh is or links to an (unpatched) bash of version 2 or newer (2.0 was released in 1996). bash drops privileges on startup. This does not only effect the ls script but also the call system() before, as system() passes the command to /bin/sh.
It may work on other distributions that do not use bash as /bin/sh. Contrary to the the information stated in the project, Ubuntu (like Debian and probably most derivatives of either) uses dash and not bash as /bin/sh and has been doing so since version 6.10 (from 2006! See this page in the Ubuntu Wiki). It seems that with recent versions of Ubuntu (at least 16.04) dash and therefore /bin/sh are patched to automatically drop SUID permissions (Look for "priv" in man dash).
Adaephon
  • 5,061
