I first tried to install the Wacom driver by following this: Ubuntu 14.04. 2 does not recognize my Wacom Intuos tablet draw (ctl-490b)
When I ran ./configure, I saw this
checking for doxygen... no
configure: WARNING: doxygen not found - documentation targets will be skipped
I wasn't sure if that was a problem or not. I decided to follow this: https://sourceforge.net/p/linuxwacom/support-requests/49/
so I typed
sudo apt-get install xutils-dev libtool xserver-xorg-dev libx11-dev libxi-dev libxrandr-dev libxinerama-dev libudev-dev
I then ran make and got
make[1]: Entering directory '/home/Downloads/xf86-input-wacom-0.33.0'
Making all in conf
make[2]: Entering directory '/home/Downloads/xf86-input-wacom-0.33.0/conf'
make[2]: Nothing to be done for 'all'.
make[2]: Leaving directory '/home/Downloads/xf86-input-wacom-0.33.0/conf'
Making all in tools
make[2]: Entering directory '/home/Downloads/xf86-input-wacom-0.33.0/tools'
make[2]: Leaving directory '/home/Downloads/xf86-input-wacom-0.33.0/tools'
Making all in test
make[2]: Entering directory '/home/Downloads/xf86-input-wacom-0.33.0/test'
make[2]: Leaving directory '/home/Downloads/xf86-input-wacom-0.33.0/test'
make[2]: Entering directory '/home/Downloads/xf86-input-wacom-0.33.0'
make[2]: Leaving directory '/home/Downloads/xf86-input-wacom-0.33.0'
make[1]: Leaving directory '/home/Downloads/xf86-input-wacom-0.33.0'
This seemed ok, so I then tried sudo make install
 /bin/mkdir -p '/usr/bin'
/bin/bash ../libtool   --mode=install /usr/bin/install -c xsetwacom isdv4-serial-debugger isdv4-serial-inputattach '/usr/bin'
libtool: install: /usr/bin/install -c xsetwacom /usr/bin/xsetwacom
libtool: install: /usr/bin/install -c isdv4-serial-debugger /usr/bin/isdv4-serial-debugger
libtool: install: /usr/bin/install -c isdv4-serial-inputattach /usr/bin/isdv4-serial-inputattach
make[2]: Nothing to be done for 'install-data-am'.
make[1]: Leaving directory '/home/Downloads/xf86-input-wacom-0.33.0/tools'
Making install in test
make[1]: Entering directory '/home/Downloads/xf86-input-wacom-0.33.0/test'
make[2]: Nothing to be done for 'install-exec-am'.
make[1]: Leaving directory '/home/Downloads/xf86-input-wacom-0.33.0/test'
I assumed this meant there were no errors. However, I don't see Wacom anywhere. I even typed
xsetwacom --list devices
sudo find . -name wacom\* | grep modules
but there was no output for either of those commands.
lsmod | grep wacom just gave
wacom                  81920  0
hid                   118784  3 wacom,hid_generic,usbhid
I then followed this: https://help.ubuntu.com/community/Wacom/LatestDriver
However, after sudo apt-get install wacom-dkms
I got
Error! Bad return status for module build on kernel: 4.2.0-36-generic (x86_64)
Consult /var/lib/dkms/wacom/0.30.0/build/make.log for more information.
I then checked /var/lib/dkms/wacom/0.30.0/build/make.log and its contents are
DKMS make.log for wacom-0.30.0 for kernel 4.2.0-36-generic (x86_64)
Building input-wacom drivers for 2.6 kernel.
make -C /lib/modules/3.13.0-68-generic/build M=/var/lib/dkms/wacom/0.30.0/build/3.7
make[1]: *** /lib/modules/3.13.0-68-generic/build: No such file or     directory.  Stop.
Makefile:24: recipe for target 'all' failed
make: *** [all] Error 2
Can anyone help?
please try following the instructions to install the kernel driver at the official support page:
http://linuxwacom.sourceforge.net/wiki/index.php/Input-wacom
