I installed ubuntu on my former windows C drive, it does not have windows on it anymore. However, once I installed Ubuntu, I cannot access my hard drive storage (which used to be D on windows)
I get this error,
I think this is because the hard drive is in NTFS? If so, is it possible to convert it in a way so Ubuntu can read and write?
αғsнιη
  • 36,350
Hello and welcome to AskUbuntu.
Use gparted to open a very useful interface that will allow you to format the drive in any way you want (create new partitions, merge or move existing ones, etc.). When you go through the options, format it to EXT4 (latest linux standard) and make sure you tick the option to mount it when starting up the computer. You will have to give it a specific mount point, say /media or /backup. This you will access through the file manager using that folder name. Note, however, that this will create a separate disc partition.
Instead, if you are new to linux, what I would suggest is that you grow the current disc partition to include that space. If you already created partitions when you started (typically swap, / and /home will be the fundamental partitions) I suggest you append the extra space to /home.
Warning: the procedure of either creating a new partition or appending the space to an existing partition will delete ALL the files currently in that partition. This process is irreversible.
GParted should be installed by default. Here is some additional information about GParted.
Juan Antonio
  • 1,602
