Hey guys I have Ubuntu 16.04 installed on my laptop now I really wanna install Windows 7 because there is always that one software that doesn't run on Ubuntu, HELP ASAP
Edit: I recently upgraded to Ubuntu 16.10 with software centre
Second Edit: My question is different because I have Ubuntu 16.10 and before I followed a Ubuntu 14.10 tutorial and it did not work and I could not boot into Ubuntu! So I had to delete Windows and Ubuntu and reinstall Ubuntu!
Third Edit: fdisk -l
So you have two options if you do not want to go the VM route.
  1. Shrink one or more of your Ubuntu partitions.
  2. Install Win 7 on an external HD.
If you need an in depth, just ask.
Best, BoB
BoB
You will have to install Windows 7 then Ubuntu. The reason behind this is cause of partitioning, Windows cannot work with Ubuntu being the first boot up.
Or you can run a VM. If you choose to run a VM read this guide:https://www.pcsteps.com/207-windows-virtual-machine-linux-windows/
Hope it helps.
Arszilla
  • 31
Even though it does not work for every program it's worth checking out if you can run the software you want in wine. Other than that you can install a VM or dual boot.
JTHO
To accomplish this, follow the instructions here. If using UEFI boot repair, if BIOS use commands.
