My Ubuntu doesn't want to install TeamViewer 11 again. :(
I had problems with sound - I tried to install Realtek HD Audio driver, but Ubuntu after installation and reboot forgot about sound chip on my motherboard and no sound was produced.
So I decided to reinstall Ubuntu (with saving my personal data including apps) using my USB Key.
Well - I had to install again GRUB Customizer, Steam and more recent apps that I use and they worked perfectly.
Without TeamViewer... TeamViewer dropped some problems with packages not installed, but after, when I wrote to terminal commend
sudo apt-get install -f
it installs these packages, uninstalling also TeamViewer.
Now when I try to install 32bit version, terminal dropps me this error:
Selecting previously unselected package teamviewer:i386.
(Reading database ... 179972 files and directories currently installed.)
Preparing to unpack .../teamviewer_11.0.67687_i386.deb ...
Unpacking teamviewer:i386 (11.0.67687) ...
dpkg: dependency problems prevent configuration of teamviewer:i386:
teamviewer:i386 depends on libpng12-0.
dpkg: error processing package teamviewer:i386 (--install):
dependency problems - leaving unconfigured
 teamviewer:i386
On 64bit version I see this error:
Selecting previously unselected package teamviewer.
Preparing to unpack .../teamviewer_11.0.67687_amd64.deb ...
Unpacking teamviewer (11.0.67687) ...
teamviewer depends on lib32asound2; however:
  Package lib32asound2 is not installed.
  teamviewer depends on ia32-libs; however:
  Package ia32-libs is not installed.
 dpkg: error processing package teamviewer (--install):
 teamviewer
So... what can I do? On Ubuntu 16.04.1 LTS worked fine.
I used this tutorial.
I have the solution for installing TeamViewer on 16.10. I hope that this will work for all.
When you see this error...
 teamviewer:i386
type sudo apt-get install -f and say "yes".
After that go to this website, download the package and install also from terminal using command
sudo dpkg -i libpng12-0_xxxxx_i386.deb
where xxxxx is the version of your libpng. I used the stable version 1.2.50-2+deb8u2.
After that again install TeamViewer and you will don't have errors. ;)
I hope that for everyone this solution will work perfectly.
Use new Teamviewer 12, it doesn't have libpng12 dependency.
Shevchuk
  • 373
