51
I'm building a bash script for my virtual machine and I would like to know how to replace a specific line in this document:
[base]
## uncomment and set autologin username to enable autologin
# autologin=dgod
## uncomment and set timeout to enable timeout autologin,
## the value should >=5
# timeout=10
## default session or desktop used when no systemwide config
# session=/usr/bin/startlxde
this line:
# autologin=dgod
I want to change to this
autologin=ubuntu
I have tried with "tee" and "sed" but couldn't make it work. This should be very easy for someone who works with bash scripts more often than me.
Zanna
  • 72,312
lewis4u
  • 5,046
You can use the s command to search and replace.
sed 's/# autologin=dgod/autologin=ubuntu/' /path/to/file
Explanation
  • s - The substitute command. The syntax is s/regexp/replacement/flags.
  • # autologin=dgod - Look for "# autologin=dgod"
  • autologin=ubuntu - Change it to "autologin=ubuntu"
  • There are no flags in this command, so it ends with /
This command sends the modified text to stdout (the command line) without modifying the source file. If the output is what you want, add -i to change the file in place:
sed -i 's/# autologin=dgod/autologin=ubuntu/' /path/to/file
Zanna
  • 72,312
I've found the most effective way to do this is actually to use the change syntax to set the exact value you want unless you are explicitly trying to enable a two way toggle. You can use this to change as well as uncomment a line no matter how it is commented, with # or // or <!--.
sed 's%searchTerm=% c searchTerm=desiredValue%' targetFile.txt
dragon788
  • 1,716
