I've managed to build and install (using checkinstall) an GNU Emacs 25.1 Debian package on 16.04, but on 16.10 for some unknown reason the compilation fails (at the make stage) giving the truncated output:
Loading language/czech...
Loading language/slovak...
Loading language/romanian...
Loading language/greek...
Loading language/hebrew...
Loading international/cp51932...
Loading international/eucjp-ms...
Loading language/japanese...
Loading language/korean...
Loading language/lao...
Loading language/tai-viet...
Loading language/thai...
Loading language/tibetan...
Loading language/vietnamese...
Loading language/misc-lang...
Loading language/utf-8-lang...
Loading language/georgian...
Loading language/khmer...
Loading language/burmese...
Loading language/cham...
Loading indent...
Loading emacs-lisp/cl-generic...
Loading frame...
Loading startup...
Loading term/tty-colors...
Loading font-core...
Loading facemenu...
Loading emacs-lisp/syntax...
Loading font-lock...
Loading jit-lock...
Loading mouse...
Loading scroll-bar...
Loading select...
Loading emacs-lisp/timer...
Loading isearch...
Loading rfn-eshadow...
Loading menu-bar...
Loading emacs-lisp/lisp...
Loading textmodes/page...
Loading register...
Loading textmodes/paragraphs...
Loading progmodes/prog-mode...
Loading emacs-lisp/lisp-mode...
Loading progmodes/elisp-mode...
Loading textmodes/text-mode...
Loading textmodes/fill...
Loading newcomment...
Loading replace...
Loading emacs-lisp/tabulated-list...
Loading buff-menu...
Loading fringe...
Loading emacs-lisp/regexp-opt...
Loading image...
Loading international/fontset...
Loading dnd...
Loading tool-bar...
Loading dynamic-setting...
Loading x-dnd...
Loading term/common-win...
Loading term/x-win...
Loading mwheel...
Loading emacs-lisp/float-sup...
Loading vc/vc-hooks...
Loading vc/ediff-hook...
Loading uniquify...
Loading electric...
Loading emacs-lisp/eldoc...
Loading cus-start...
Loading tooltip...
Loading /home/fusion809/Programs/emacs-25.1/lisp/leim/leim-list.el (source)...
Finding pointers to doc strings...
Finding pointers to doc strings...done
Dumping under the name emacs
Makefile:736: recipe for target 'bootstrap-emacs' failed
make[1]: *** [bootstrap-emacs] Segmentation fault (core dumped)
make[1]: Leaving directory '/home/fusion809/Programs/emacs-25.1/src'
Makefile:398: recipe for target 'src' failed
make: *** [src] Error 2
To be clear I ran:
./autogen.sh && ./configure --prefix=/usr --with-x-toolkit=gtk2 && make
and it was at the make stage that the build failed. I did run sudo apt-get build-dep -y emacs24 before running these commands.
EDIT: I can confirm that this segmentation fault occurs even when the --with-x-toolkit=gtk2 option is substituted with --with-x-toolkit=gtk3.
