I have Ubuntu 16.04 LTS on Lenovo z5170. I want to have a program (no matter what programming language) that notifies me that i'm running low on battery by a beep. I assume that the program should be sleeping until the moment that i'm out of battery(10% energy) but all I can think of is a while loop which eats up the whole processor and keeps everything else from running.
1- How should I implement such program ?
2- Which are the ways to notify users on specific event ?
Shadow_m2
  • 165
In addition to the suggested duplicate methods, what you can do is this:
Find your battery interface path via upower -enumerate:
bash-4.3$ upower --enumerate
/org/freedesktop/UPower/devices/line_power_ACAD
/org/freedesktop/UPower/devices/battery_BAT1
/org/freedesktop/UPower/devices/DisplayDevice
Then use upower --show-info and trip its output. In my example that would be like so:
bash-4.3$ upower --show-info /org/freedesktop/UPower/devices/DisplayDevice | awk '/percentage/{gsub(/\%/,""); print $2}'
100
All you have to do now, is use a simple script to compare if that output value is less than or equal to certain threshold
#!/bin/bash
get_percentage()
     # Note, | \ must have only new line after it, no space
     upower --show-info /org/freedesktop/UPower/devices/battery_BAT1 |\
main()
    while true
    do
        pcent=$(get_percentage)
        [ $pcent -le 10  ] && notify-send "Battery Low" "Please plug in charger"
        sleep 60 # check every minute
    done
main
As for notifying via beep, you could use aplay command and any audio file instead of notify-send. If you don't have GUI, you can also use wall command like so wall <<< "Battery low" and it will print to screen a message. NOTE: because of recent updates in gnome-terminal this doesn't work in gnome-terminal, but in TTYs and other terminal emulators it still does
