At the login screen of my Ubuntu box, I select Ubuntu under the cog menu, but it loads the 2D version instead of the 3D version.
I'm running:
- Asus P5Q Pro
- Intel Core 2 Quad Q6600 @ 2.40GHz x4
- GeForce 9600GT (1024MB)
- 32-bit OS
- 4x 1GB DDR2 RAM Modules (although BIOS only shows I'm using ~3GB)
Is this setup not capable of running Unity 3D? I understand that it won't install it if it's not supported!
unity_support_test output:
penGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce 9600 GT/PCI/SSE2
OpenGL version string: 3.3.0 NVIDIA 290.10
Not software rendered: yes
Not blacklisted: yes
GLX fbconfig: yes
GLX texture from pixmap: yes
GL npot or rect textures: yes
GL vertex program: yes
GL fragment program: yes
GL vertex buffer object: yes
GL framebuffer object: yes
GL version is 1.4+: yes
Unity 3D supported: yes
glxinfo output after driver reinstall:
direct rendering: Yes
GL_NV_path_rendering, GL_NV_pixel_data_range, GL_NV_point_sprite,
