22
Whenever I boot Ubuntu 16.10, just before the Plymouth screen, I'm seeing this message:
No symbol table found.
Press any key to continue...
and it remains there for a minute or so before showing me the log in screen. If I press any key it will be stuck for ever and I'll have to restart the computer.
Any help is appreciated..
Ron
  • 20,938
Try this one, first from USB/Live CD (if you can't access Ubuntu from HDD), and then, or directly from your "HDD OS":
sudo fdisk -l
This will list all partitions on your HDD. Find under the Type section your root partition labelled Ubuntu or Linux and its Device (like /dev/sda).
Then, do
sudo grub-install /dev/sdX
Where sdX is the device you found with fdisk. Note that you install GRUB to a drive, not a partition, so sda would be correct while sda1 would be incorrect.
Finally, run
sudo update-grub
sudo reboot
Zanna
  • 72,312
I also got this when trying to update from 16.04 LTS to 18.04 LTS. However, when trying the sudo grub-install command as mentioned I get:
Installing for i386-pc platform.
grub-install: error: failed to get canonical path of '/cow'.
But by following these instructions instead I solved my problem:
How to Repair, Restore, or Reinstall Grub 2 with a Ubuntu Live CD or USB
FlyingD
  • 453
