I'm trying to install caffee and torch on Ubuntu, but there are some unmet dependency problems. I have searched on the Internet for days but still cannot fix it. Can someone help? Thanks.
Below are the errors shown in terminal:
libopencv-dev : Depends: libopencv-objdetect-dev (= 2.4.9.1+dfsg+1.5ubuntu1) but it is not going to be installed
Depends: libopencv-highgui-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not going to be installed
Depends: libopencv-legacy-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not going to be installed
Depends: libopencv-contrib-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not going to be installed
Depends: libopencv-videostab-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not going to be installed
Depends: libopencv-superres-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not going to be installed
Depends: libopencv-ocl-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not going to be installed
Depends: libcv-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not going to be installed
Depends: libhighgui-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not going to be installed
Depends: libcvaux-dev (= 2.4.9.1+dfsg-1.5ubuntu1) but it is not going to be installed
root@mingchuan-ThinkPad-T420:~/torch $ sudo apt-get install --no-install-recommends libboost-all-dev
Reading package lists... Done
Building dependency tree
libboost-all-dev : Depends: libboost-date-time-dev but it is not going to be installed
Depends: libboost-filesystem-dev but it is not going to be installed
Depends: libboost-iostreams-dev but it is not going to be installed
Depends: libboost-log-dev but it is not going to be installed
Depends: libboost-system-dev but it is not going to be installed
Depends: libboost-thread-dev but it is not going to be installed
Depends: libboost-wave-dev but it is not going to be installed
root@mingchuan-ThinkPad-T420:~/torch#
