Today I upgraded my system from 14.04 to 16.04. During the upgrade process some errors occurred in installation phase but the upgrade completion message was shown. After restarting the system and while booting up, kernel panic message was shown. So I started the system with the most recent working kernel on my machine (actually this one didn't boot up either at first, but I could get around that). Now whenever I want to use apt-get, the following errors are shown (particularly the message awk: symbol lookup error: awk: undefined symbol: mpfr_z_sub is shown after running commands like dpkg or sometimes after pressing tab for tab completion in terminal):
$ sudo apt-get install -f
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
386 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up libpaper1:amd64 (1.1.24+nmu4ubuntu1) ...
dpkg: error processing package libpaper1:amd64 (--configure):
 subprocess installed post-installation script returned error exit status 127
dpkg: dependency problems prevent configuration of cups-daemon:
 cups-daemon depends on libpaper1; however:
  Package libpaper1:amd64 is not configured yet.
dpkg: error processing package cups-daemon (--configure):
 dependency problems - leaving unconfigured
Setting up locales (2.23-0ubuntu3) ...
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: error processing package locales (--configure):
dpkg: dependency problems prevent configuration of language-pack-en-base:
 language-pack-en-base depends on locales (>= 2.3.6); however:
  Package locales is not configured yet.
dpkg: error processing package language-pack-en-base (--configure):
dpkg: dependency problems prevent configuration of language-pack-en:No apport report written because MaxReports is reached already
 language-pack-en depends on language-pack-en-base (>= 1:16.04+20160627); however:
  Package language-pack-en-base is not configured yet.
dpkg: error processing package language-pack-en (--configure):
dpkg: dependency problems prevent configuration of language-pack-gnome-en-base:No apport report written because MaxReports is reached already
 language-pack-gnome-en-base depends on locales (>= 2.3.6); however:
dpkg: error processing package language-pack-gnome-en-base (--configure):
                                                              dpkg: dependency problems prevent configuration of language-pack-gnome-en:
 language-pack-gnome-en depends on language-pack-gnome-en-base (>= 1:16.04+20160627); however:
  Package language-pack-gnome-en-base is not configured yet.
 language-pack-gnome-en depends on language-pack-en; however:
  Package language-pack-en is not configured yet.
dpkg: error processing package language-pack-gnome-en (--configure):
                                                              Setting up initramfs-tools (0.122ubuntu8.3) ...
update-initramfs: deferring update (trigger activated)
Setting up samba-common (2:4.3.11+dfsg-0ubuntu0.16.04.1) ...
dpkg: error processing package samba-common (--configure):
                                                              dpkg: dependency problems prevent configuration of smbclient:
 smbclient depends on samba-common (= 2:4.3.11+dfsg-0ubuntu0.16.04.1); however:
  Package samba-common is not configured yet.
dpkg: error processing package smbclient (--configure):
                                                              Setting up rsyslog (8.16.0-1ubuntu3) ...
dpkg: error processing package rsyslog (--configure):
                                                              dpkg: dependency problems prevent configuration of ubuntu-minimal:
 ubuntu-minimal depends on locales; however:
 ubuntu-minimal depends on rsyslog; however:
  Package rsyslog is not configured yet.
dpkg: error processing package ubuntu-minimal (--configure):
                                                              Setting up gconf2-common (3.2.6-3ubuntu6) ...
dpkg: error processing package gconf2-common (--configure):
                                                              dpkg: dependency problems prevent configuration of libgconf-2-4:amd64:
 libgconf-2-4:amd64 depends on gconf2-common (= 3.2.6-3ubuntu6); however:
  Package gconf2-common is not configured yet.
dpkg: error processing package libgconf-2-4:amd64 (--configure):
                                                              dpkg: dependency problems prevent configuration of gconf-service-backend:
 gconf-service-backend depends on libgconf-2-4 (= 3.2.6-3ubuntu6); however:
  Package libgconf-2-4:amd64 is not configured yet.
 gconf-service-backend depends on gconf2-common (= 3.2.6-3ubuntu6); however:
dpkg: error processing package gconf-service-backend (--configure):
                                                              dpkg: dependency problems prevent configuration of libgconf2-4:amd64:
 libgconf2-4:amd64 depends on libgconf-2-4 (= 3.2.6-3ubuntu6); however:
dpkg: error processing package libgconf2-4:amd64 (--configure):
                                                              dpkg: dependency problems prevent configuration of gconf2:
 gconf2 depends on libgconf-2-4 (>= 3.2.6-3ubuntu6); however:
 gconf2 depends on gconf-service-backend (= 3.2.6-3ubuntu6); however:
  Package gconf-service-backend is not configured yet.
dpkg: error processing package gconf2 (--configure):
                                                              dpkg: dependency problems prevent configuration of aisleriot:
 aisleriot depends on gconf2 (>= 2.28.1-2); however:
  Package gconf2 is not configured yet.
 aisleriot depends on libgconf-2-4 (>= 3.2.5); however:
dpkg: error processing package aisleriot (--configure):
                                                              dpkg: dependency problems prevent configuration of alarm-clock-applet:
 alarm-clock-applet depends on libgconf-2-4 (>= 3.2.5); however:
 alarm-clock-applet depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing package alarm-clock-applet (--configure):
                                                              dpkg: dependency problems prevent configuration of gnome-terminal:
 gnome-terminal depends on libgconf-2-4 (>= 3.2.5); however:
dpkg: error processing package gnome-terminal (--configure):
                                                              dpkg: dependency problems prevent configuration of libgs9:amd64:
 libgs9:amd64 depends on libpaper1; however:
dpkg: error processing package libgs9:amd64 (--configure):
                                                              dpkg: dependency problems prevent configuration of ghostscript:
 ghostscript depends on libgs9 (= 9.18~dfsg~0-0ubuntu2); however:
  Package libgs9:amd64 is not configured yet.
dpkg: error processing package ghostscript (--configure):
                                                              dpkg: dependency problems prevent configuration of printer-driver-sag-gdi:
 printer-driver-sag-gdi depends on ghostscript; however:
  Package ghostscript is not configured yet.
dpkg: error processing package printer-driver-sag-gdi (--configure):
                                                              dpkg: dependency problems prevent configuration of cups-core-drivers:
 cups-core-drivers depends on cups-daemon (>= 2.1.3-4); however:
  Package cups-daemon is not configured yet.
dpkg: error processing package cups-core-drivers (--configure):
                                                              dpkg: dependency problems prevent configuration of cups-filters:
 cups-filters depends on ghostscript (>= 9.02~); however:
dpkg: error processing package cups-filters (--configure):
                                                              dpkg: dependency problems prevent configuration of cups:
 cups depends on cups-core-drivers (>= 2.1.3-4); however:
  Package cups-core-drivers is not configured yet.
 cups depends on cups-daemon (>= 2.1.3-4); however:
 cups depends on ghostscript (>= 9.02~); however:
 cups depends on cups-filters (>= 1.0.24-3~); however:
  Package cups-filters is not configured yet.
dpkg: error processing package cups (--configure):
                                                              dpkg: dependency problems prevent configuration of printer-driver-gutenprint:
 printer-driver-gutenprint depends on cups (>= 1.3.0); however:
  Package cups is not configured yet.
 printer-driver-gutenprint depends on cups-filters (>= 1.0.36) | ghostscript-cups (<< 9.08); however:
  Package ghostscript-cups is not installed.
  Version of ghostscript-cups on system, provided by cups-filters:amd64, is <none>.
dpkg: error processing package printer-driver-gutenprint (--configure):
                                                              dpkg: dependency problems prevent configuration of printer-driver-pxljr:
 printer-driver-pxljr depends on cups-filters (>= 1.0.42) | foomatic-filters (>= 4.0.0~bzr156); however:
  Package foomatic-filters is not installed.
  Version of foomatic-filters on system, provided by cups-filters:amd64, is <none>.
dpkg: error processing package printer-driver-pxljr (--configure):
                                                              dpkg: dependency problems prevent configuration of printer-driver-hpcups:
 printer-driver-hpcups depends on cups; however:
 printer-driver-hpcups depends on cups (>= 1.4.0) | cupsddk; however:
  Package cupsddk is not installed.
 printer-driver-hpcups depends on cups-filters (>= 1.0.36) | ghostscript-cups; however:
  Package cups-filters which provides ghostscript-cups is not configured yet.
dpkg: error processing package printer-driver-hpcups (--configure):
                                                              dpkg: dependency problems prevent configuration of hplip:
 hplip depends on cups (>= 1.1.20); however:
 hplip depends on printer-driver-hpcups (= 3.16.3+repack0-1); however:
  Package printer-driver-hpcups is not configured yet.
dpkg: error processing package hplip (--configure):
                                                              dpkg: dependency problems prevent configuration of printer-driver-postscript-hp:
 printer-driver-postscript-hp depends on hplip (>= 3.16.3+repack0-1); however:
  Package hplip is not configured yet.
dpkg: error processing package printer-driver-postscript-hp (--configure):
                                                              dpkg: dependency problems prevent configuration of printer-driver-foo2zjs:
 printer-driver-foo2zjs depends on cups-filters | foomatic-filters; however:
  Package cups-filters which provides foomatic-filters is not configured yet.
dpkg: error processing package printer-driver-foo2zjs (--configure):
                                                              dpkg: dependency problems prevent configuration of bluez-cups:
 bluez-cups depends on cups; however:
dpkg: error processing package bluez-cups (--configure):
                                                              Setting up udisks2 (2.1.7-1ubuntu1) ...
dpkg: error processing package udisks2 (--configure):
                                                              dpkg: dependency problems prevent configuration of gvfs-daemons:
 gvfs-daemons depends on udisks2; however:
  Package udisks2 is not configured yet.
dpkg: error processing package gvfs-daemons (--configure):
                                                              dpkg: dependency problems prevent configuration of gvfs:amd64:
 gvfs:amd64 depends on gvfs-daemons (>= 1.28.2-1ubuntu1~16.04.1); however:
  Package gvfs-daemons is not configured yet.
 gvfs:amd64 depends on gvfs-daemons (<< 1.28.2-1ubuntu1~16.04.1.1~); however:
dpkg: error processing package gvfs:amd64 (--configure):
                                                              dpkg: dependency problems prevent configuration of nautilus:
 nautilus depends on gvfs (>= 1.3.2); however:
  Package gvfs:amd64 is not configured yet.
dpkg: error processing package nautilus (--configure):
                                                              dpkg: dependency problems prevent configuration of brasero:
 brasero depends on gvfs; however:
dpkg: error processing package brasero (--configure):
                                                              dpkg: dependency problems prevent configuration of python3-checkbox-support:
 python3-checkbox-support depends on udisks2; however:
dpkg: error processing package python3-checkbox-support (--configure):
                                                              dpkg: dependency problems prevent configuration of plainbox-provider-resource-generic:
 plainbox-provider-resource-generic depends on python3-checkbox-support (>= 0.22); however:
  Package python3-checkbox-support is not configured yet.
dpkg: error processing package plainbox-provider-resource-generic (--configure):
                                                              dpkg: dependency problems prevent configuration of plainbox-provider-checkbox:
 plainbox-provider-checkbox depends on plainbox-provider-resource-generic (>= 0.17); however:
  Package plainbox-provider-resource-generic is not configured yet.
 plainbox-provider-checkbox depends on python3-checkbox-support (>= 0.22); however:
dpkg: error processing package plainbox-provider-checkbox (--configure):
                                                              dpkg: dependency problems prevent configuration of checkbox-converged:
 checkbox-converged depends on plainbox-provider-checkbox; however:
  Package plainbox-provider-checkbox is not configured yet.
dpkg: error processing package checkbox-converged (--configure):
                                                              dpkg: dependency problems prevent configuration of checkbox-gui:
 checkbox-gui depends on checkbox-converged; however:
  Package checkbox-converged is not configured yet.
dpkg: error processing package checkbox-gui (--configure):
                                                              Setting up upower (0.99.4-2ubuntu0.3) ...
dpkg: error processing package upower (--configure):
                                                              dpkg: dependency problems prevent configuration of indicator-power:
 indicator-power depends on upower; however:
  Package upower is not configured yet.
dpkg: error processing package indicator-power (--configure):
                                                              dpkg: dependency problems prevent configuration of unity-control-center:
 unity-control-center depends on indicator-power; however:
  Package indicator-power is not configured yet.
dpkg: error processing package unity-control-center (--configure):
                                                              dpkg: dependency problems prevent configuration of indicator-bluetooth:
 indicator-bluetooth depends on unity-control-center | gnome-control-center | ubuntu-system-settings; however:
  Package unity-control-center is not configured yet.
  Package gnome-control-center is not installed.
  Package ubuntu-system-settings is not installed.
dpkg: error processing package indicator-bluetooth (--configure):
                                                              Setting up php7.0-common (7.0.8-0ubuntu0.16.04.3) ...
dpkg: error processing package php7.0-common (--configure):
                                                              dpkg: dependency problems prevent configuration of php7.0-json:
 php7.0-json depends on php7.0-common (= 7.0.8-0ubuntu0.16.04.3); however:
  Package php7.0-common is not configured yet.
dpkg: error processing package php7.0-json (--configure):
                                                              dpkg: dependency problems prevent configuration of php7.0-opcache:
 php7.0-opcache depends on php7.0-common (= 7.0.8-0ubuntu0.16.04.3); however:
dpkg: error processing package php7.0-opcache (--configure):
                                                              dpkg: dependency problems prevent configuration of php7.0-readline:
 php7.0-readline depends on php7.0-common (= 7.0.8-0ubuntu0.16.04.3); however:
dpkg: error processing package php7.0-readline (--configure):
                                                              dpkg: dependency problems prevent configuration of php7.0-cli:
 php7.0-cli depends on php7.0-common (= 7.0.8-0ubuntu0.16.04.3); however:
 php7.0-cli depends on php7.0-json; however:
  Package php7.0-json is not configured yet.
 php7.0-cli depends on php7.0-opcache; however:
  Package php7.0-opcache is not configured yet.
 php7.0-cli depends on php7.0-readline; however:
  Package php7.0-readline is not configured yet.
dpkg: error processing package php7.0-cli (--configure):
dpkg: too many errors, stoppingNo apport report written because MaxReports is reached already
Processing triggers for libc-bin (2.23-0ubuntu3) ...
Processing triggers for initramfs-tools (0.122ubuntu8.3) ...
dpkg: error processing package initramfs-tools (--configure):
 libpaper1:amd64
 cups-daemon
 locales
 language-pack-en
 samba-common
 smbclient
 rsyslog
 ubuntu-minimal
 gconf2-common
 libgconf-2-4:amd64
 libgconf2-4:amd64
 gconf2
 aisleriot
 alarm-clock-applet
 gnome-terminal
 libgs9:amd64
 ghostscript
 cups-core-drivers
 cups-filters
 cups
 hplip
 bluez-cups
 udisks2
 gvfs-daemons
 gvfs:amd64
 nautilus
 brasero
 checkbox-converged
 checkbox-gui
 upower
 indicator-power
 indicator-bluetooth
 php7.0-common
 php7.0-json
 php7.0-opcache
 php7.0-readline
 php7.0-cli
 initramfs-tools
Processing was halted because there were too many errors.
I don't know what causes this problem. I also tried sudo apt-get -f dist-upgrade command but only linux-headers and linux-image-extra version 4.4.0-43.63 were installed and then the above message was appeared.
How can I resolve this issue? Is this related to libpaper1 package?
today
  • 111
