Using Ubuntu 16.04, I installed powerline (sudo apt install powerline); I enabled it for bash successfully, but when I tried to enable it in my .vimrc file, using the following lines:
" Powerline
set rtp+=/usr/share/powerline/bindings/vim/
set laststatus=2
set t_Co=256
it didn't work. I did some troubleshooting, and discovered that /usr/share/powerline/bindings/vim/ doesn't exist, although there are folders for a number of other bindings (e.g., bsh, awesome, etc.).
Eliah Kagan
  • 119,640
Jeremy
  • 506
For those here from Google, add the following to ~/.vimrc if you have installed powerline from your distribution (sudo apt-get install powerline).
set rtp+=/usr/share/vim/addons/
set laststatus=2
set t_Co=256
franek
Samuurai
  • 131
The following:
sudo cp -r /home/$USER/.local/lib/python3.5/site-packages/powerline/bindings/vim /usr/share/powerline/bindings
fixed for me, on Ubuntu 16.04. Please replace $USER accordingly. You may also need to replace python3.5 folder in that path with the correct python version for which powerline has been installed.
I don't know why binding for vim is not available system-wide by default, i.e. placed under /usr/share/powerline/bindings/, though.
