I have installed readpst package and while converting pst file to mbox using "readpst -r outlook.pst".I get following error message:
Could not get root record
I had this issue using the -S switch. I compacted the PST and then it seemed to work. According to the source code comment the problem is "first record is main record":
d_ptr = pstfile.d_head; // first record is main record
item = pst_parse_item(&pstfile, d_ptr, NULL);
if (!item || !item->message_store) {
DEBUG_RET();
DIE(("Could not get root record\n"));
Hope this helps anyone with the same problem.
