I've never written a script before, and I need help with my first one.
I have 3 commands, that need to run in order, in separate windows.
How do i write a script that I can execute, that runs command one, command two, and command three, in order, in separate windows?
I have tried making sense out of other posts, but haven't had any luck
Andy Bennett
  • 41
You can do it just by calling three instances of your terminal emulator and telling them to stay open with exec bash
Example:
#!/bin/bash
mate-terminal -x bash -c 'uname -r; exec bash'
mate-terminal -x bash -c 'uname -m; exec bash'
mate-terminal -x bash -c 'uname -s; exec bash'
The first terminal pops up with 4.4.0-42-generic second one with x86_64, third one with Linux...
If you're using vanilla Ubuntu, then replace mate-terminal with gnome-terminal or whatever app you use. Replace uname -[rms] with your commands. You may find you need to use -e and not -x for gnome-terminal.
Help from this answer posted by Chaos
Zanna
  • 72,312
Assume that the commands are command_1, command_2 .. command_n. Then do the following
(You can also use terminal, or konsole, or gnome-terminal, instead of xterm, as mentioned here ).
 $ xterm -e command_1
 $ xterm -e command_2
 $ xterm -e command_n
