I have Kubuntu 16.04 and am using ZFS.
As you can see on superuser, I just had a long journey in tracking down where my memory was vanishing to.
It turned out to be the ARC of ZFS that was eating it up without showing up anywhere in the tools/files other than its own special file /proc/spl/kstat/zfs/arcstats
Is there a generic way to see how much memory is used by the kernel and if possible, by which kernel modules?
Example:
free -h was showing me this:
total used free shared buff/cache available
Mem: 31G 19G 1.8G 406M 10G 5.2G
Swap: 8.0G 0B 8.0G
So 19GB in use. But TOP only showed me about 8GB of used memory. So I went in search of the other 11GB.
6GB turned out to be slab which can be seen in /proc/memstat and with nmon. But 5GB were still missing.
In the end I found that it had been consumed by the ARC of ZFS. But it was only listed in its own special info file. /proc/spl/kstat/zfs/arcstats
Neither /proc/memstat nor top, htop, nmon, free, or atop could tell me who is using those 5GB.
Is there a file/tool to see the memory used by such special modules, without knowing/understanding those modules? Or do I have to account for every existing module if I would want to write a monitoring tool that can tell me this?
From my perspective, memory info under linux is a total mess. Dozen of number that all don't add up to total memory. I bet free calculates the "in use" parameter by substracting free/cache/buffers from the total.
I would like to have/write a tool/info where I can see
Total memory: 32GB
in use: 19GB
processes: 8GB
slab: 5GB
mapper: 1Gb
kernel modules: 5Gb
kernel: 0.3GB
spl: 4.7GB
cache: 6GB
buffers: 2GB
free: 5GB
Additional stats:
Active memory: 8.3GB
Active(anon): 7.1GB
Active(file): 1.2GB
Inactive memory: 2.4GB
You know, where each subsection actually addes up to its parent section and each byte of memory is accounted for ;)
So is such a tool possible under Linux? Does it exist already?
Update 1
The tool smem as suggested below indeed shows a colum "Dynamic kernel memory" which sums up to 100% of memory and accounts for ARC. However according to this answer
BTW: I already checked smem sources, it basically does (memtotal - userspace - free - cache).
So this is only achieved by simply substracting all known figures from /proc/memstat and labeling what is missing as "noncache Dynamic Kernel Memory" I find this disturbing and really hope the linux kernel has more to offer than that.
